Very High Receive Errors 7204 Router
derrickcameron
Hello All,
I have a 7204 router that is getting an extremely high number of receive errors daily. Somewhere around a million receive errors a day.  I've included the show interface output below, please let me know if you need any other information. It's not a speed or duplex mismatch. This port is an internet connection to part of our network using a sub interface.
FastEthernet0/0 is up, line protocol is up
Hardware is i82543 (Livengood), address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 3/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/209640/178354 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1351000 bits/sec, 508 packets/sec
5 minute output rate 299000 bits/sec, 342 packets/sec
4182135577 packets input, 147943558 bytes
Received 1834601577 broadcasts, 0 runts, 0 giants, 2386 throttles
121195941 input errors, 0 CRC, 0 frame, 15183091 overrun, 106012850 ignored
0 watchdog
3048370593 packets output, 4157164315 bytes, 0 underruns
5 output errors, 0 collisions, 2 interface resets
5 lost carrier, 0 no carrier
Seb Rupik
Hi there,
It looks like fa0/0 is on a linecard/ module which is not capable at switching the volume of data that it is receiving; hence the large overrun and input drop/flush numbers.
What module does the swithport reside on?
sh inv
sh module
cheers,
Seb.
5 Replies 5
Seb Rupik
Hi there,
sh inv
sh module
cheers,
Seb.
Here's the show inventory output, but I can't use the show module.
Also thanks Seb.
show inventory
NAME: "Chassis", DESCR: "Cisco 7204VXR, 4-slot chassis"
PID: CISCO7204VXR      , VID:    , SN: 31652262
NAME: "NPE400 0", DESCR: "Cisco 7200VXR Network Processing Engine NPE-400"
PID: NPE-400           , VID: V01 , SN: 35693087
NAME: "module 0", DESCR: "I/O Dual FastEthernet Controller"
PID: C7200-I/O-2FE/E   , VID:    , SN: 31687305
NAME: "disk0", DESCR: "Cisco 7200 I/O PCMCIA Flash Disk, 64M"
PID: MEM-I/O-FLD64M    , VID:    , SN:
NAME: "Power Supply 1", DESCR: "Cisco 7200 AC Power Supply"
PID: PWR-7200-AC       , VID:    , SN:
NAME: "Power Supply 2", DESCR: "Cisco 7200 AC Power Supply"
show hw-module all fpd
                             H/W   Field Programmable   Current   Min. Required
Slot Card Type               Ver.  Device: "ID-Name"    Version      Version
 npe NPE-400                 2.1   ############           #.#         #.#
I can't find much infomration on the C7200-I/O-2FE/E modules switch performance. From the interface output I'd say you have reached its limit.
I encountered a similar issue on 7206VXR router a few years back which was remedided by moving the traffic to a more capable linecard/ interface:
http://config-if.blogspot.co.uk/2013/08/cisco-7206vxr-fa-ge-port-adapter.html
...however you have nowhere to move the link to. Consider either policing the traffic before it reaches your 7204, or ebaying yourself some new components.
cheers,
Seb.
Thanks Seb
I'll let you know if a better NPE fixes the issue
