video streaming
christianeze
hi,
we want to implement video streaming but i can anybody help m with the cisco 2800 series router that supports video streaming.
thanks
mheusinger
Level 10
Level 10
have a look at
IP Videoconferencing Solution Reference Network Design (SRND)
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns280/c649/ccmigration_09186a00800d67f6.pdf
and also at
Cisco AVVID Network Infrastructure IP Multicast Design (SRND)
http://www.cisco.com/application/pdf/en/us/guest/tech/tk363/c1501/ccmigration_09186a008015e7cc.pdf
If those guides are not helpful you need to be more specific about your desired result, topology and issues you are running into.
Hope this helps! Please rate all posts.
Regards, Martin
Amit Singh
In addition to Martin's post, If you want to implement video streaming across the WAN than ACNS is the way to go.
http://www.cisco.com/en/US/products/sw/conntsw/ps491/index.html
http://www.cisco.com/en/US/products/sw/conntsw/ps491/products_data_sheet0900aecd80261a22.html
HTH,Please rate if it does.
-amit singh
