!!vlan isolation!!
francisco_1
Level 7
Level 7
I have couple of vlans i am routing on our core network. Inter-vlan routing is enable for all vlans but i would like to isolate few of the vlans. I dont want any traffic routed between those vlans. is vrf the way forward? Can vrf completely isolate the vlans traffic?
Joseph W. Doherty
Yes, VRF might be used. The "Lite" variant ties routing table instances to VLANs. Useful if you want multiple routed networks running on the same platforms that don't directly (and normally) "see" each other.
Lots of information can be found starting here: http://www.cisco.com/en/US/netsol/ns658/index.html
cameron.moody
Using private-vlans might be another option as well?
thanks to you both.
Francisco
