VLAN
narayanaccna100
Help.
How to change port from One VLAN to Other VLAN..in a switch.
Reply
Nagendra Kumar Nainar
interface
switchport mode access
switchport access vlan
HTH,
Nagendra
thanks a lot
hasnain321
If you just want to switch the port to another vlan go to that interface configuration mode and type
switch port access vlan XX
where XX is your vlan number.
If you have CatOS then type set vlan 2 XX where XX is your port number
switchport mode acess
switchpo access vlan
