Vpn client output
alsayed
hello!
what this output means in the attached file?
mheusing
Make sure the Cisco VPN service is started. You can check this from the "Services" control panel or more simple with the task manager, where you should see a process called "cvpnd.exe".
If this service is not started it will create the message you experienced.
Hope this helps! Please rate all posts.
Regards, Martin
Hi mheusing!
10xs a lot
