VPN IPsec over Dialer interface not working
vanscarlat
I am completely out of ideas and I rely on the community's help to make a Cisco 881 router finally work.
I have the following configuration:
Current configuration : 2964 bytes
! No configuration change since last restart
version 15.1
no service pad
no service dhcp
hostname HOSTNAME
boot-start-marker
boot-end-marker
no logging console
enable secret 4 Nq2Qa3VgUxOFKhtuNYSfTjmG8tcryP67rejoLPHyZ4Q
enable password PASSWORD
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no process cpu autoprofile hog
memory-size iomem 10
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-3171263040
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3171263040
revocation-check none
rsakeypair TP-self-signed-3171263040
ip source-route
no ip cef
ip name-server x.x.x.151
ip name-server x.x.x.152
no ipv6 cef
license udi pid CISCO881-K9 sn SERIALNO
username UNAME privilege 15 secret 4 crXTpaYLDkjN6CD9fmkh71./aAHmBSTDMR/AkifA20U
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key SECRET address x.x.x.202
crypto isakmp keepalive 10 5 periodic
crypto isakmp aggressive-mode disable
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto map VPN-Map-01 10 ipsec-isakmp
set peer x.x.x.202
set transform-set 3DES-SHA
set pfs group2
match address Crypto-list-01
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description DSL Interface
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface Vlan1
description Internal LAN
ip address 192.168.110.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password 0 PASSWORD
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list DSL_ACCESSLIST interface Dialer1 overload
ip nat inside source route-map RMAP_1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended Crypto-list-01
permit ip 192.168.110.0 0.0.0.255 192.168.10.0 0.0.0.255
ip access-list extended DSL_ACCESSLIST
permit ip 192.168.110.0 0.0.0.255 any
access-list 101 deny   ip 192.168.110.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.110.0 0.0.0.255 any
route-map RMAP_1 permit 10
match ip address 101
line con 0
line aux 0
line vty 0 4
transport input all
end
The following is the result of SHOW CRYPTO SESSION:
Interface: Dialer1
Session status: UP-ACTIVE
Peer: x.x.x.202 port 500
  IKEv1 SA: local x.x.x.161/500 remote x.x.x.202/500 Active
  IPSEC FLOW: permit ip 192.168.110.0/255.255.255.0 192.168.10.0/255.255.255.0
        Active SAs: 2, origin: crypto map
Interface: Virtual-Access1
Session status: DOWN
Peer: 216.223.131.202 port 500
        Active SAs: 0, origin: crypto map
As much as I understand, the VPN tunnel is active.
I can access the Internet, but I cannot access anything through the VPN tunnel.
Can you help me, please, with this problem?
Thank you very much,
Van
At least you have a mistake in the NAT-config which can interfere with the traffic that should be sent through the tunnel. Remove the following line and try again:
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Thanks for answering this!!!!!
vanscarlat
Wow. Thanks, Karsten. It is working now.
ZBF follows. It is quite rediculuous, because this router was originalkly configured for a static public IP. Then, I had to move it on an ADSL connection and nothing was working anymore - of course, I first defined the Dialer interface and added the layer over FA4. Having the ZBFW active, I couldn't even access the Internet.
After that, I saved that configuration and started from scretch. Now, I have Internet and - with your help - VPN. I will continue with the ZBFW in small steps.
Thank you very much.
For a setup that is really simple (two interfaces) I would stick with the legacy CBAC because of the simplicity. In your case the basic config would be like the following:
ip inspect name FW tcp  router-traffic
ip inspect name FW udp  router-traffic
ip inspect name FW icmp router-traffic
ip inspect name FW ftp
interface Dialer 1
ip inspect FW out
ip access-group OUTSIDE-IN in
ip access-list ext OUTSIDE-IN
deny ip any any
