VRF configuration
raajesh8228
Community Member
Can any one help me out with the VRF configuration details.
Need to implement in our campus in cisco 6509 switch.
Provide the sample configuration steps.
Rajesh
Akash Agrawal
Hi Rajesh,
You can go through below links, if any doubt let us know
http://ciscodreamer.blogspot.com/2009/06/vrf-basics.html
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/profiles/SBC_Config_Examplebook/vrf_examples.html
VRF - Virtual Route Forwarding
It creates a virtual routing table and routing of traffic, coming on interfaces which are part of that vrf, will be done through that virtual routing table
It is having two components
RD - Route Distinguisher
RT - Route Target
RD acts as route distinguisher on RR for overlapping subnets for different customers. RD local to the router and should be unique on that router. Same RD can not be assigned to two VRFs on same router.
RT is extended community. You can export multiple RT along with vpnv4 BGP updates. Based on RT
remote side router can accept interested prefixes with RT import on that vrf.
RD is part of the prefix while RT travels as extended community.
--Pls dont forget to rate helpful posts--
Akash
Akash Agrawal
Hi Rajesh,
RT - Route Target
Akash
Hi Rajesh,
Thanks for accepting the post as solution accepted and rate it. However i would like to know what additional info could have made it up to rating 5.
Akash
