VRF setup problem
elizabethf
Community Member
Hello, I'm having quite some trouble setting up my VRFs and I was wondering if anyone here could tell me what I'm doing wrong.  The network topology is as shown on the picture. I have to setup two VRFs using BGP - one for CE_Prague and CE_Warsaw, and another VRF for CE_Barcelona and CE_Florence. I already did that - I made a vrf named ELI for the first two, and a vrf named KATI for the second two. The problem is the two CE routers that belong to the same VRF cannot see each other, therefore, cannot ping each other which is the main task. I'm really stuck and I don't know what I'm supposed to do so I'd be very glad if any of you can help me. 😞Image 1.03.23 at 13.35.jpeg
Hi @elizabethf ,
I have various observations from the configs you posted.
- You have no VPNv4 configuration between the PE and the RR as noted by @MHM Cisco World .
- Your CE do not advertised their loop back addresses, which I suppose is the goal of the exercise.
for instance CE Warsaw should have a network statement as follow:
network 192.168.0.3 mask 255.255.255.248
- Since both CEs within the same VRF have the same AS, the update will not be accepted from one CE to the other, unless you configure the following on the BGP session towards the CE on the PE.
neighbor x.x.x.x as-override
25 Replies 25
you need three step
redistribute the prefix from routing protocol  you run between CE-PE into BGP (address ipv4 vrf)
redistribute the prefix from BGP into CE-PE routing protocol
last must sure the route-target in both side is mirror meaning
import in one side is same as export on other side, for lab it better use route-target both x:x
I use BGP between CE and PE, I have done everything and it still doesnt work...
Did you redistreibte connect under add family ipv4 in both side?
If not only add redistrubte connect and check again
i redistributed the connected routes under both of them - the ipv4 family and the bgp.. they still can't see each other
share the config of CE PE on both side
CE_xxx:
interface GigabitEthernet1/0
ip address 87.85.83.17 255.255.255.252
negotiation auto
interface GigabitEthernet2/0
ip address 87.85.83.21 255.255.255.252
negotiation auto
interface GigabitEthernet3/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet5/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet6/0
no ip address
shutdown
negotiation auto
router bgp 65000
no synchronization
bgp log-neighbor-changes
neighbor 87.85.83.18 remote-as 1234
neighbor 87.85.83.22 remote-as 1234
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
PE_xxx
hostname xxx
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
ip vrf ELI
rd 1:1
route-target export 1:1
route-target import 1:1
no ip domain lookup
no ipv6 cef
mpls label protocol ldp
archive
log config
  hidekeys
ip tcp synwait-time 5
interface Loopback0
ip address 200.200.200.3 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
ip address 87.85.80.17 255.255.255.252
negotiation auto
mpls ip
ip address 87.85.80.21 255.255.255.252
negotiation auto
mpls ip
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
ip address 87.85.83.26 255.255.255.252
negotiation auto
ip vrf forwarding ELI
ip address 87.85.83.18 255.255.255.252
negotiation auto
router ospf 1
mpls ldp autoconfig
log-adjacency-changes
redistribute connected subnets
redistribute bgp 1234 subnets
network 87.85.80.16 0.0.0.3 area 0
network 87.85.80.20 0.0.0.3 area 0
network 200.200.200.3 0.0.0.0 area 0
router bgp 1234
no synchronization
bgp redistribute-internal
network 87.85.80.16 mask 255.255.255.252
network 87.85.83.16 mask 255.255.255.252
network 87.85.83.24 mask 255.255.255.252
network 200.200.200.8 mask 255.255.255.255
neighbor 87.85.83.17 remote-as 65000
neighbor 87.85.83.25 remote-as 65000
neighbor 195.193.191.1 remote-as 1234
neighbor 195.193.191.5 remote-as 1234
neighbor 200.200.200.7 remote-as 1234
neighbor 200.200.200.7 update-source Loopback0
neighbor 200.200.200.8 remote-as 1234
neighbor 200.200.200.8 update-source Loopback0
no auto-summary
address-family ipv4 vrf ELI
  redistribute static
  neighbor 87.85.83.17 activate
  no synchronization
exit-address-family
no ip http server
no cdp log mismatch duplex
mpls ldp router-id Loopback0
control-plane
PE_xxx
hostname xxx
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
ip vrf ELI
rd 1:1
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
interface Loopback0
ip address 200.200.200.1 255.255.255.255
no ip address
shutdown
duplex half
ip address 87.85.80.1 255.255.255.252
negotiation auto
mpls ip
ip address 87.85.80.5 255.255.255.252
negotiation auto
mpls ip
ip address 87.85.83.2 255.255.255.252
negotiation auto
ip address 87.85.83.10 255.255.255.252
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 1
mpls ldp sync
mpls ldp autoconfig
network 87.85.80.0 0.0.0.3 area 0
network 87.85.80.4 0.0.0.3 area 0
network 200.200.200.1 0.0.0.0 area 0
router bgp 1234
no synchronization
network 87.85.80.0 mask 255.255.255.252
network 87.85.80.4 mask 255.255.255.252
network 87.85.83.0 mask 255.255.255.252
network 87.85.83.8 mask 255.255.255.252
neighbor 87.85.83.1 remote-as 65000
neighbor 87.85.83.9 remote-as 65000
no auto-summary
  redistribute static
  neighbor 87.85.83.1 activate
  no synchronization
exit-address-family
no ip http server
CE_xxx
hostname xxxx
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
interface Loopback0
ip address 192.168.0.3 255.255.255.248
no ip address
shutdown
duplex half
ip address 87.85.83.1 255.255.255.252
negotiation auto
ip address 87.85.83.5 255.255.255.252
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router bgp 65000
no synchronization
neighbor 87.85.83.2 remote-as 1234
neighbor 87.85.83.6 remote-as 1234
no auto-summary
no ip http server
control-plane
gatekeeper
shutdown
you config is missing VPNv4 config
what you need
add LO in each PE
advertise this LO in OSPF
then
router bgp x
neighbor LO-of-far-PE remote x
neighbor LO-of-far-PE update source LO-of-this-PE
address family vpnv4 unicast
neighbor LO-of-far-PE activate
I have two route reflectors, so the bgp sessions are established between RR and PE, I dont have PE to PE bgp configuration. So how am I supposed to do the vpnv4 configuration then? I'm sorry about my dumb questions but I'm a newbie.
No
use same config I share above but not between
PE1-PE2 but between PE's-RR
and then
config in RR
neighbour PE1-LO route-reflector-client
neighbour PE2-LO route-reflector-client
 neighbour PE1-LO activate
 neighbour PE2-LO activate
Hi @elizabethf ,
Thank you very much for the answer, so I added a vpnv4 configuration on both of the Route Reflectors, and I also added the
as-override
command on the PE routers but I still can't get the CEs to recognise each other. I don't know what the issue could be... My teacher told me not to use the loopbacks on the CEs so that's why I haven't set them up yet.
share the last config of
CE PE and RR
redistribute connect under the address family ipv4 vrf <<- only correct this and try again
address-family vpnv4
  neighbor 200.200.200.1 activate
 neighbor 200.200.200.1 route-reflector-client <<- you also need route-reflector-cleint under VPNv4 for ALL PE's
After doing all of the things you recommended, this is the routing table of CE_Warsaw
87.0.0.0/30 is subnetted, 4 subnets
B       87.85.83.16 [20/0] via 87.85.83.2, 00:35:22
B       87.85.83.20 [20/0] via 87.85.83.2, 00:35:34
C       87.85.83.0 is directly connected, GigabitEthernet1/0
C       87.85.83.4 is directly connected, GigabitEthernet2/0
so that means that CE_Warsaw now knows about the other CE in the VRF, and they can successfully ping each other. But when i type in sh ip bgp sum this is the result:
Neighbor        V          AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
87.85.83.2      4       1234      45      41        9    0    0 00:36:24        4
87.85.83.6      4       1234      40      41        9    0    0 00:36:29        4
Is this how it's supposed to be? Shouldn't the route to CE_Prague be present in the bgp table since they are in the same VRF or?
