VRF Static Route
FrankZ49
Hi there,
Can someone explain the difference between the following commands:
1. ip route 10.0.0.0/24 10.1.1.1 vrf TEST-vrf1
2. vrf context TEST-vrf1
Thanks.
Frank
Francesco Molino
They are basically the same thing. Using the static route within vrf context you can have a static route with a next hop associated to another vrf if you go into vrf context and type in ip route x.x.x.x/x x.x.x.x vrf xxxx (leaking).
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
Francesco,
Thank you for the clarification.
Frank
