want to buy router
Faisal Shabbir
hi ,
please anyone could suggest me the which router meets the below mentioned specs :
  • Hardware Architecture
  • Should be based on modular architecture for scalability and should be a single box configuration for ease of management with the flexibility to use the appropriate choice of interfaces as and when required.
  • The router offered should have high MTBF & low MTTR
  • Power supply should be for 230V AC.
  • May have redundant Power supply, not mandatory.
  • Should have Min of 512 MB RAM & 256 MB FLASH and should be upgradeable.
  • Interface
  • Should have at least 3 Gig interfaces (at least 1 SFP Port)
  • Should have at least 2 FE interface
  • Dedicated Console port
  • At least 1 USB port
petr
  • Performance
  • Should provide performance of at least 700kpps
  • Routing table should be able to take more than 13k of routes.
  • Should support performance enhancement through hardware based encryption.
  • Router should support other IP Services like
    • GRE
    • IPSec VPN
    • SSL VPN
    • Tunnel-less/Client-Less VPN
    • Firewall
    • Should support MLPPP for link aggregation
  • Protocol Support
    • Should support Routing protocols like
    • RIP ver1 &2
    • OSPFv2 and v3
    • BGP4
      • Should support the following IP Multicast routing protocols
      • IGMPv1 and v2
      • PIM-SM
      • PIM-DM.
        • Should support following IPv6 features:
        • DHCPv6,
        • IPv6 QoS,
        • IPv6 Multicast support,
        • RIP
        • OSPFv3 for IPv6.
          • Should support MPLS Features
          • Should support IP Accounting features
          • Should support HSRP
  • QoS Features
  • Should support Classification and Marking:
  • Policy based routing
  • IP Precedence
  • DSCP
  • MPLS exp bits
  • Congestion Management:
  • Random Early Detection
  • Priority queuing
  • Class based weighted fair queuing
  • Traffic Conditioning:
  • Committed Access Rate/Rate limiting
  • Link efficiency mechanisms:
  • MLPPP
  • Per VLAN QoS.
  • Resource Reservation Protocol (RSVP)
  • Support for Auto-QoS
  • Security Features
  • multi-level of access
  • SNMPv3 authentication, SSHv2
  • AAA support using Radius and/or TACACS
  • IP Access list and SNMP access to router
  • Multiple privilege level authentications for console and telnet access
  • Time based & Dynamic ACLs.
  • MAC address authentication
  • Management
  • Should have support for CLI, Telnet and SNMPv3
  • Should support Secure Shell
  • Should provide a provision to analyze IP service levels for IP applications and services by using active traffic monitoring (the generation of traffic in a continuous, reliable, and predictable manner) for measuring network performance.
  • Should support hardware assisted flow-based traffic analysis of applications, hosts, performance-based measurements on application and network latency, quality of experience metrics for network-based services such as voice over IP (VoIP) and video.
  • Should have the ability to monitor events and take informational, corrective, action when the monitored events occur or when a threshold is reached.
  • Implementation control configuration on the Router to ensure SNMP access to SNMP Manager or the NMS work station.
  • Support for RMON1/RMON2.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I haven't verified all your listed features but a 3925 router would probably meet most of your them.
Leo Laohoo
I agree with Joseph.  This sounds like a 3925
The 3925 already comes with default three 1 Gbps interface (1 SFP dual-personality port).  So you need to purchase additional module(s) for the fastethernet ports.  You can either have a routed or a switchport.
