WCS Error Adding Controller
cherylfarria
Hello, I am having a problem adding a controller to WCS. I am able to ping and communicate between the WCS box and the controller but when I try to add the controller it erross stating "Failed to add device to WCS Reason: Object not found in device" Has anyone seen this before? I have added them before at other locations with no problem?
8 Replies 8
cherylfarria
Also when I try to add the controller from WCS the controller log has the following:
MACADDR_GET_FAIL: Interface 1 source MAC address is not found.
vegardkjer
did you find a solution to this problem?
i have the same problem.
Hi Friend,
Can you make sure if snmp is properly configured on your controller? Can you enable "debug snmp all enable" and then try adding the controller and see what debug messages you get?
Ankur
I am having the same problem. The customer has confirmed the SNMP setting. I am not getting any errors. Please help
I can get the snmp to send traps from the controller to the WCS box but still cannot add it..
I get the following error when trying to add.. Failed to add device to WCS:Object not found in device
Thanks!!
what version of wlc and wcs are you running?
Wireless Control System
Version 4.1.83.0
WLC 4400
4.2.61.0
thanks!
i think the problem is a mismatch between wlc version and wcs version.
i have a wcs version 4.2.81.0 and one wlc 2106 version 4.2.99.0 and one wlc 2106 version 4.0.217.0.
the wlc2106 version 4.2.99.0 added ok.
but the wlc2106 version 4.0.217.0 failed.
after upgrading the second wlc2106 to version 4.2.112.0 it also added ok.
in your case, i'm sure you need a newer wcs version to support the wlc version 4.2.61.0.
hope this helps.
