What is configure on CE using EVPN method Multihoming Active Active
ditoprasetya
Please send me other reference link documentation on cisco apart from this "https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l2_vpns/configuration/xe-16-9/mp-l2-vpns-xe-16-9-book/evpn-multihoming.html" because this documentation not explain for configure on CE/Switch.
Thank's
Dito Prasetya
5 Replies 5
pman
CE1 uses a port channel consisting of links, L11 and L12, to connect to PE1 and PE2, respectively.
the port channel can support flow-based load balancing for traffic egress towards PE1 and PE2.
Hope the information helped.
Hi pman,
Thanks for the reply.
when I configure the lacp on the port on the router CE the port turns off. Can I use the "ON" mode?
Because I using version the router CSR on the my eve-ng still running 16.09.07
pman
LACP should configure according to the following example (without "on" mode):
side 1: active
side 2: active
OR
side 1: active
side 2: passive
Hi pman,
Actually, I mean I'm not using LACP on the port. is it possible to use the on mode without using the active-active or active-passive LACP method for from CE to PE ?
pman
yes,
If I'm not mistaken it should be something like this:
side1:
interface GigabitEthernet1
channel-group 1 mode on
!There are versions that do not have the word "on" and the following command is sufficient: "channel-group 1"
interface Port-channel1
ip address 1.1.1.2 255.255.255.0
side2:
ip address 1.1.1.1 255.255.255.0
output example:
Router# show etherchannel summary
Flags: D - down P/bndl - bundled in port-channel
I - stand-alone s/susp - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group     Port-channel        Protocol     Ports
1            Po1(RU)                                 Gi1(P)
RU - L3 port-channel UP State
SU - L2 port-channel UP state
P/bndl - Bundled
S/susp - Suspended
In the case of EVPN Multihoming I saw the following restrictions:
Restrictions for EVPN Multihoming
  • The number of bridge domains that are supported are 16000.
  • The number of EFPs or service instances that are supported per physical interface are 8000.
  • Stateful Switchover is not supported.
  • IP learning is not supported on Cisco ASR 1000 Series Aggregation Services Routers.
  • Only all-active redundancy mode (2 or 2+ PEs in the same redundancy group sharing the same ESI and all forwarding traffic) is supported.
  • Single-active mode is not supported.
  • Only access-side flow-based load balancing with multihoming LAG ON mode is supported. Any ether-channel signaling (LACP or PAgP) is not supported.
  • MAC mobility and duplication detection is not supported.
  • Per-EVI and per-MAC labeling is not supported. Only per-BD and per-CE labeling is supported.
  • Only type 3 ESI is supported as defined in section 5 of RFC7432. Type 3 ESI consists of PE System MAC address and local discriminator.
  • Port-channel signaling is not supported.
  • The port-channel should be configured in ON mode only.
