What NAT setting do I have missing?
fieryhail
Hello all, I am trying to host a server accessible from the internet on port 80. I have Static IP and dns setup pointing to my router, and NAT inside the router creating a static NAT route to LAN computer. I can access the LAN machine from inside the network by IP, but I can't access it all from the internet. Please help. I'll supply detailed config info if necessary
7 Replies 7
CriscoSystems
Level 5
Level 5
"I'll supply detailed config info if necessary"
It's necessary.
Building configuration...
Current configuration : 2489 bytes
version 12.4
hostname c3662
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef table adjacency-prefix validate
ip cef
ip domain name rcserveny.com
ip name-server 167.206.112.138
ip name-server 167.206.7.4!
interface FastEthernet0/0
ip nat inside
ip nat allow-static-host
ip nat enable
ip virtual-reassembly
speed auto
full-duplex
interface FastEthernet0/1
ip address 96.56.78.172 255.255.255.248
ip nat outside
ip nat enable
speed auto
full-duplex
router rip
redistribute connected
network 96.0.0.0
network 192.168.1.0
ip default-gateway 96.56.78.169
no ip http server
ip route 0.0.0.0 0.0.0.0 96.56.78.169
ip nat log translations syslog
ip nat source static tcp 192.168.1.11 21 interface FastEthernet0/1 21
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.1.1 443 interface FastEthernet0/1 443
ip nat inside source static tcp 192.168.1.11 80 interface FastEthernet0/1 80
ip nat inside source static tcp 192.168.1.1 636 interface FastEthernet0/1 636
ip nat inside source static tcp 192.168.1.11 389 interface FastEthernet0/1 389
ip nat inside source static tcp 192.168.1.11 563 interface FastEthernet0/1 563
ip nat inside source static tcp 192.168.1.11 119 interface FastEthernet0/1 119
ip nat inside source static tcp 192.168.1.11 993 interface FastEthernet0/1 993
ip nat inside source static tcp 192.168.1.11 995 interface FastEthernet0/1 995
ip nat inside source static tcp 192.168.1.11 465 interface FastEthernet0/1 465
ip nat inside source static tcp 192.168.1.11 143 interface FastEthernet0/1 143
ip nat inside source static tcp 192.168.1.11 110 interface FastEthernet0/1 110
ip nat inside source static tcp 192.168.1.11 25 interface FastEthernet0/1 25
ip nat inside source static tcp 192.168.1.101 5900 interface FastEthernet0/1 420
ip nat inside source static tcp 192.168.1.12 22 interface FastEthernet0/1 22
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
gateway
timer receive-rtp 1200
line con 0
line aux 0
line vty 0 4
login
end
my running-config, I truncated it to remove the empty lines and password info.
I would try taking off the ip nat enable and the ip nat allow-static-host off of the interfaces.
Also, after creating these, you may need to either reload the router or try to clear out nat translations. I've had to do both on routers before they started answering correctly.
clear ip nat trans *
HTH,
John
HTH, John *** Please rate all useful posts ***
I did as you suggested, however, the problem exists, same as before, outgoing is ok, nothing incoming except for the transfer of email
Try changing the line below:
to
ip nat inside source static tcp 192.168.1.11 21 int fa0/1 21
See if that helps.
John
Thank you for your replies, I have tried as you suggested but it is still not working properly. I'm getting out from the server here, but I can not access the server at all from the outside :-(. Public IP only goes nowhere because that would be the cisco itself and I have http server disabled. I'm thinking about tearing the router down and redoing it from a basic setup, only add the ip nat inside and outside to the interfaces and then create ip nat inside source static tcp 192.168.1.11 80 int fa0/1 80, as well as the other necessary ports to forward (SMTP, IMAP, SSL, LDAP, etc.) If this works I'll let you know, if this doesn't I'll let you know. I'm getting frustrated, it must be some simple setting or syntax error that I am confusing.
Thanks for all your help. I cleared the router and redid it, adding the ACL for my internal LAN and then a static nat for the mailserver to go out. Thanks again for all your help, everythng works now. Next issue is how to setup a VPN on the cisco. If anyone has an comments, I'd like to hear them.
