Why BGP need an IGP
sugatada9
guys I have a question here. I saw BGP always needs another protocol like OSPF or EIGRP etc. to propegate routes. Why this is so? Also the same route propegation can be done with BGP
Network
command?
Harold Ritter
Hi Sugata,
This is mostly the case with iBGP, which is generally configured using the router loopback interface address rather than the directly connected interface address. This is very useful as the BGP session will not go down if the physical interface goes down as long as there is a backup path to the peer router loopback address. The IGP is used to establish the BGP session (TCP session) and to resolve the BGP next hop.
eBGP, on the other hand, is generally configured using the directly connected interface address.
Harold Ritter
Hi Sugata,
