Why my LocalDirector 430 can not works?
jeff.chang
Hello,friends:
I am a chinese man,so please forget my pool english first!I have two servers and there are two jboss servers on each one servers.I use LD 430 to load balancing.The before configuation is below: lb(config)# show config ...... hostname lb no shutdown ethernet 0 no shutdown ethernet 1 no shutdown ethernet 2 no shutdown ethernet 3 interface ethernet 0 auto interface ethernet 1 auto interface ethernet 2 auto interface ethernet 3 10baset mtu 0 1500 mtu 1 1500 mtu 2 1500 mtu 3 1500 multiring all no secure 0 no secure 1 no secure 2 no secure 3 ping-allow 0 ping-allow 1 ping-allow 2 ping-allow 3 ip address 10.0.0.2 255.255.255.0 route 0.0.0.0 0.0.0.0 10.0.0.1 1 arp timeout 30 no rip passive rip version 1 failover ip address 0.0.0.0 no failover failover hellotime 30 password xxxx encrypted telnet 218.x.x.x.255.255.0 telnet 10.0.0.0 255.255.255.0 telnet 211.x.x.x.255.255.0 no snmp-server enable traps snmp-server community public no snmp-server contact no snmp-server location tftp-server 192.168.1.41 port 69 conf virtual 10.0.0.205:80:0:tcp is virtual 10.0.0.205:8080:0:tcp is real 10.0.0.101:8081:0:tcp is real 10.0.0.100:8081:0:tcp is real 10.0.0.101:8080:0:tcp is real 10.0.0.100:8080:0:tcp is name 10.0.0.101 server2 name 10.0.0.100 server1 name 10.0.0.205 vserver no names bind 10.0.0.205:80:0:tcp 10.0.0.100:8080:0:tcp bind 10.0.0.205:80:0:tcp 10.0.0.100:8081:0:tcp bind 10.0.0.205:80:0:tcp 10.0.0.101:8080:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.101:8081:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.100:8080:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.101:8080:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.100:8081:0:tcp probeconfig http 3. It works well. But now I want add a virtual IP 10.0.0.205:9090 to bind 10.0.0.100:8080,so I can access the service on the port 9090 on website.so I config again,but the virtual can not work,that means that I can not access the website on port 9090.What is wrong with the virtual IP?,the current configuation is below: lb(config)# show config ...... hostname lb no shutdown ethernet 0 no shutdown ethernet 1 no shutdown ethernet 2 no shutdown ethernet 3 interface ethernet 0 auto interface ethernet 1 auto interface ethernet 2 auto interface ethernet 3 10baset mtu 0 1500 mtu 1 1500 mtu 2 1500 mtu 3 1500 multiring all no secure 0 no secure 1 no secure 2 no secure 3 ping-allow 0 ping-allow 1 ping-allow 2 ping-allow 3 ip address 10.0.0.2 255.255.255.0 route 0.0.0.0 0.0.0.0 10.0.0.1 1 arp timeout 30 no rip passive rip version 1 failover ip address 0.0.0.0 no failover failover hellotime 30 password xxx encrypted telnet 218.x.x.x.255.255.0 telnet 10.0.0.0 255.255.255.0 telnet 211.147.5.0 255.255.255.0 no snmp-server enable traps snmp-server community public no snmp-server contact no snmp-server location tftp-server 192.168.1.41 port 69 conf virtual 10.0.0.205:80:0:tcp is virtual 10.0.0.205:8080:0:tcp is virtual 10.0.0.205:9090:0:tcp is predictor 10.0.0.205:9090:0:tcp leastconns none real 10.0.0.101:8081:0:tcp is real 10.0.0.100:8081:0:tcp is real 10.0.0.101:8080:0:tcp is real 10.0.0.100:8080:0:tcp is replicate 10.0.0.205:9090:0:tcp name 10.0.0.101 server2 name 10.0.0.100 server1 name 10.0.0.205 vserver no names bind 10.0.0.205:80:0:tcp 10.0.0.100:8080:0:tcp bind 10.0.0.205:80:0:tcp 10.0.0.100:8081:0:tcp bind 10.0.0.205:80:0:tcp 10.0.0.101:8080:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.101:8081:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.100:8080:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.101:8080:0:tcp bind 10.0.0.205:8080:0:tcp 10.0.0.100:8081:0:tcp bind 10.0.0.205:9090:0:tcp 10.0.0.100:8080:0:tcp probeconfig http 3
thanks a lot!
b.hsu
Level 5
Level 5
Do you have the LD's clock set to GMT? In order for cookie-sticky to work the LD's clock needs to be set to GMT.
