WRVS4400N Router
keithwalz
My ISP requires that I be able to hard set the WAN port to 100Mbs Full Duplex.  Is this possible with the WRVS4400N?
I see an option to set the switch ports but not the WAN port.
Thanks for any help
Giuseppe Larosa
Hello Keith,
thanks to Conor that posted it in another thread there is an emulation of the GUI
http://ui.linksys.com/files/WRVS4400N/1.00.12/switch_vlan.htm
let's see under port settings it is possible see
http://ui.linksys.com/files/WRVS4400N/1.00.12/switch_port.htm
you just need to select 100 full in the Mode column
Hope to help
Giuseppe
Thanks, but that is the settings for the switch ports, I need to be able to set the WAN port to 100mbps Full Duplex
Hello Keith,
you are absolutely right.
it looks like there is no way to hardcode speed and duplex on wan port on the GUI
Hope  to help
Giuseppe
