X25 map rbp remote
gilmarmaia2011
We have a Cisco C2901/K9 and we need to do a setup for accepting X.25 connections and converting them into TCP sessions to a server.
Currently we are using Translate method to exchange data between server and router, but at moment we are trying to use the RBP method, because we are getting fragmentation on TCP sessions.
The problem on the RBP command is that we don't want to specify a unique x121-address argument because we want to accept any incoming X.25 calls. With the Translate command we can do this using regular expressions, but apparently RBP command does not accept regular expressions.
Does anyone know how to configure the router for accepting ANY incoming X.25 calls using X25 map RBP command?
Thanks in advance.
0 Replies 0
