xot
istorman
Community Member
At xot, there is 5 second delay between disconnection tcp session and x25. Is it possible to decrease that value?
Thanks.
smahbub
Level 11
Level 11
you can play with the following options on the router where you
initiate the XOT tunnel ;
"X25 route XOT" options :
xot-keepalive-period Specify TCP keepalive period
xot-keepalive-tries Specify TCP keepalive tries
for the TCP sessions terminated on the router you can play with the
global commands :
Service tcp-keepalives-in Generate keepalives on idle incoming network
connections
Service tcp-keepalives-out Generate keepalives on idle outgoing network
connections
which will help you to fasten to detect an hanging TCP session.
