Beginning in the 12.2(33)SXI4 software release, Quad-Sup Uplink Forwarding is supported which allows for a redundant supervisor to fully boot Cisco IOS Software, thereby providing a deterministic recovery option for redundant supervisors in a VSS cha...
Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
Knowledge Base Articles
Design and Configuration Guide:Best Practices for Virtual Port Channels (vPC) on Cisco Nexus 7K Switches
There is support with some caveats specifically around the always connect feature. "Apple iOS 7 no longer supports Always Connect domains. When running AnyConnect on Apple iOS 7 devices, any domains listed as Always Connect will be treated as Connect...
BYOD-Advanced Guest Wireless AccessThis guide addresses the following technology use cases: Self-Administered Advanced Guest Wireless AccessAn authorized employee can administer a guest wireless networkthat supports time-based customized guest user ...
