Cat8300 - No controllers - Autonomous mode
Steytler
I'm trying to help my customer who purchased Cat8300 prior to my engagement, with the expectation they could do payload encryption with VIT.
I know these are SD-WAN boxes but here's my question:  If the customer purchased the enterprise SD-WAN license but keeps the devices in Autonomous mode, can we configure them with a VTI to do payload encryption?
thanks,
Steytler
Of course.
Autonomous mode does this. You don't need DNA or SDWAN to run IPSec or any other traditional routing/ tunnelling/ crypto on C8K routers.
HTH,
HTH,
6 Replies 6
    Considering this router can work as autonomous (all of them actually can) and assuming VTI can be configured in autonomous router (you can see here ) then the conclusion is yes, with appropriate licensing this router can stablish VTI ipsec with another router.
thanks,  I'm familiar with VTI's.  I'm just trying to get this customer a solution without having to order new equipment.  the 8300's have been on order for a year.
Cisco C8300 has 2 types of licenses: network stack (essential/ advantage) and DNA subscription (essential/ advantage/ premier -- btw premier may be removed recently). In any case, you have at least network stack essential w/ some DNA subscription.
See "Cisco DNA for Routing perpetual features" > VPN Support in below link:
https://www.cisco.com/c/m/en_us/products/software/sd-wan-routing-matrix.html
If you configure router as traditional w/ IPSEC, bandwidth tier must be at least required IPSec throughput.
https://www.cisco.com/c/en/us/products/collateral/software/one-wan-subscription/nb-06-dna-sw-rout-sub-faq-ctp-en.html
HTH,
HTH,
The question needs to be simply stated:
Does the 8300 have the ability to do payload encryption WITHOUT some type of software defined architecture - SD-WAN, DNA or otherwise.
I want to use the 8300 the same way I would use an ISR - like a router that can do IPSec encryption with the correct flavor of OS.
Thanks!
Of course.
HTH,
HTH,
Steytler
Thank you - that's the answer/direction I was looking for.
