cEdge - Logs or debug for IPsec connection attempts
jgardner150
Level 4
Level 4
Hello Community!
I have had an established fully functional site running an ISR1100 with SDWAN. Just last week I lost tunnels on my MPLS connection and even though I have full connectivity (can ping all other edges, no firewalls in path, MPLS circuit seems OK..) I can not get tunnels to re-form on the MPLS path, even tried rebooting the cEdge a couple times as last resort... My biz-internet and LTE interfaces have active tunnels / bfd sessions and seem to be fine, control connections are good. This site is managed by a device template I have several other site working on with no issue and running on the same MPLS network as the other sites. There were no configuration changes made that I am aware of.
I was wondering if anyone knows what show commands / logs / debugs I could look at to see if connection attempts are being made / why they are failing.
I do have a TAC case open (not helpful so far). But.. I feel like this is something I should be able to dig deeper into to find possible cause without TAC.
jgardner150
Level 4
Level 4
Just wanted to closes the loop on this since I worked with TAC and got some help. Appears I am hitting this bug CSCvp12683. This happens randomly after reboot and usually can be corrected by flapping the link. I am still working this with them to get info they need for a fix.
