Cisco Sdwan Controll plane not geting UP
Hi Team,
We have deployed the controllers in ESXi and the vEdge router in PNet. We are able to push all templates and configure the devices in vManage, but there are no OMP details on any vEdge routers. Additionally, no vSmart details appear on the vEdge devices when we run the "show control connections" command, i checked the details like basic configuration(certificate,site-id,sys ip,organizations)unable to resolve the issue.
I have attached the details of all controllers and routers below. Please help me resolve this issue.
14 Replies 14
configure sp-organization-name cool  on all controllers as well.
You may check the issue by running "show control connection-history" command.
HTH,
i have configured the same on all controllers and vedge routers, but still same.
I also asked for control history output, share it
HTH,
Please find the logs,
there are many show
can you share last state one show connect history
MHM
also from vedge
ping vbond <<- FQDN of vbond
ping ip <vmanage> source interface <vpn 0 interface>
MHM
Please find logs,
we are using ip for vBond not fqdn,
10.80.24.194 is vBond, 10.80.24.193 is vSmart and 10.80.24.192 is vManage
sorry are there two vmanage ? one .192 and .193 ?
MHM
Only one vManage .192 ,
.193 is vsmart
In edge
Show control local-proper
Share this if yoh can
In vbond
Show orchest connection-history
MHM
please find the sh control connections-history output
Hi @shivakumarAN45992,
Based in your logs you've a DISTLOC error and the root cause can be the lack of color configuration inside tunnel interface on vSmart. Remember that TLOC is represented by three-tuple, consisting of system IP, link color and encapsulation.
DISTLOC    - TLOC Disabled.
 Best regards
******* If This Helps, Please Rate *******
Are this issue solved
MHM
Strange, vedge does not initiate control connection to vsmart even.
Share show control local-properties from vedge
HTH,
