02-07-2024 04:37 AM
is it possible to create sdwan tunnel on a transport without having controll connection through it.
Solved! Go to Solution.
02-07-2024 06:25 AM
yes, "max-control connections 0" under tunnel interface is the command that you need. Command tells to router not to create control connections over interfaces, but create BFD towards routers.
Tech tip |
Deployment C requires the use of max-control-connections 0 under the MPLS tunnel interface, which tells the WAN Edge router that the TLOC is not expected to have control connections. The MPLS TLOC is advertised via the control connection on the Internet side and data plane connections can still form with other WAN Edge routers over the MPLS transport. |
02-07-2024 02:48 PM
Command is
Sdwan interface <interface name> tunnel-interface max-control connection <number>
Here we can specify the interface and config max control connection to be 0.
This prevent transport interface from established any control connection
MHM
02-07-2024 04:40 AM
I will more check' but I think yes
You can have two or more transport interface' use one to connect to vsmart/vmanage and use other to connect as data tunnel to other vedge.
MHM
02-07-2024 04:43 AM
yes, theoretically it should, i am looking for some documention or if someone has achieved this.
02-07-2024 02:48 PM
Command is
MHM
02-07-2024 06:25 AM
Tech tip |
02-11-2024 09:09 PM
i am sure you all will be knowing this but just wanted to update...
for all the interfaces assigned private IP and public color (edge device placed behind a firewall) it is must to create control connections for BFD and ipsec tunnel to come up. without the control connections vManage will not know the public IP used for NAT.
TLOC colour is used to decide which IP to use for tunnel creation.
regards,
