SD-WAN 16.12.3 Release ISR 4331 with NIM-ES2-4 module blocking device template from beeing deployed
Danijel Zelic
We are struggeling with an ISR 4331 router with NIM-ES2-4 module. The device has its control connections established to the controllers -> everything fine. Now we just want to deploy our prepared device template with our branch site configuration, but all we get is:
bad-cli - Interface GigabitEthernet0/1/0, parser-context - Interface GigabitEthernet0/1/0Error received from the device is :
bad-cli - Interface GigabitEthernet0/1/1, parser-context - Interface GigabitEthernet0/1/1Error received from the device is :
bad-cli - Interface GigabitEthernet0/1/2, parser-context - Interface GigabitEthernet0/1/2Error received from the device is :
bad-cli - Interface GigabitEthernet0/1/3, parser-context - Interface GigabitEthernet0/1/3Error received from the device is :
bad-cli - Vlan internal allocation policy ascending, parser-context - Vlan internal allocation policy ascendingError received from the device is
The mentioned interfaces are related to NIM-ES2-4 module.
We did try to add switchport in the device template like in the picture below, but without success, the error stays the same.image.png
Any advices?
kind regards Danijel
Danijel Zelic
Okay we are replacing the NIM module as the actual NIM module seems to be faulty.
