SD-WAN Active-Standby Cluster Disaster Recovery Latency Requirements
klasko16
Our team is looking to add in another management cluster in an alternate location, and registering them in an active-standby disaster recovery configuration. I am finding that intra-cluster traffic has a more strict latency requirement of <4ms while the inter-cluster latency requirement hasn't been formally established. If we have 2 NOC locations with about 25-30ms in latency between them, would we experience issues with the cluster interface/replication traffic?
Hello.
I couldnt find any documents about the latency for DR.
As you saw, Cluster needs <4ms latency.
Perhaps, 25-30 ms wont be matter If link is stable.
The DR replication will be successful.
Try to open the case If you need.
Thank you.
Joseph W. Doherty
Cluster vendor's technical support likely best to answer that question.
On the face of it, if cluster documentation says 4 ms or less, and you have 25 to 30 ms, that's quite a delta.
Some questions that might make some difference, is the 4 ms latency one way or round trip?  Is the 4 ms for some kind of heartbeat that might be subjected to QoS to minimize queuing latency impact?  Is there any way to "tune" the value to allow for increased latency?
