SD-WAN controller deployment on-premise with Disaster-recovery
Mario Rosi
Hi guys,
i'd be very happy to receive any feedbacks from the expert ones about this scenario:
- my customer wants to implement on premise the controllers deployment
- it wants to use disaster-recovery for resiliency of solution (their are going to promote themselves as SD-WAN provider)
- the controllers site must be accessed by two different underlay: Satellite (Private IP space for TLOCs) and Internet (privage IP space for TLOCs) infrastructures
Based on what described here https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/BRKRST-2559.pdf on slide 15-16:
- WAN Edge points to the vBond FQDN that resolves both public and private IP.
- WAN Edge communicates with vSmart and vManage NATed public IP over Internet and use private IPs over MPLS
- Private color to private color uses private IP, public color to public color uses public IP.
- vSmart and vManage point to the vBond NATed public IP.
- vBond learns interface private and NATed IP address of vSmart and vManage.
- vSmart and vManage use private IPs for communication
- vSmart and vManage use private color (non-default).
...and that sounds good for me and match good enough with my scenario having Satellite instead of MPLS.
Now, i'm proposing this design below where:
- vSmart, vManage are in one DMZ and one segment VLAN
- vBond in in another DMZ and another segment VLAN
- i've two vBond for redundancy
- i've two FW for redundancy
- i've two sites one with vManage cluster active and the one for disaster recovery with vManage cluster in standby
- vSmart, vBond and FWs are all active on both the two sites (so traffic of control may cross through the L2 DCI between the two sites)
My questions:
1) Is ok for you as design?
2) may i avoid to have the two FWs used to let vBonds to communicate with vSmart and vManage, configured in cluster active/standby and just let them to work each one alone?
3) How could work the NAT-ing between vManage/vSmart and vBond on both the sites (may you explain a little better how cisco is suggesting to deploy this scenario in general?)
I attach my schemas and the flow of control plane traffic among the vEdge and controller and among controllers themselves.
I really would appreciate your contribution, being an important project where the Satellite infrastructure would be used aside the other classic ones.
Mario
0 Replies 0
