SD-WAN router Public internet tunnel wont establish behind firewall
We have the fallowing scenario:
- I have published all my sdwan controller to the public with 1:1 nat for each controller and placed them on DMZ zone.
- I have 2 Routers for testing each router have 4G modem connected to it (normal internet with a shared public ip address) these router where able to form control connection with SD-WAN controllers using public internet TLOC.
- The testing router were able to form tunnel between each other with no issue and testing using VRF 1 (VPN 1 ) as a service vpn to see traffic going between them
- I have a Router in the Datacenter behind a firewall (Same firewall that have controllers connected to it) and i have two public ISP connected to the firewall for internet connectivity , I have done the routing to establish internet connection for this router but i failed to establish control connection with controllers for some reason that i dont know.
- But i have a spare of public ip addresses and done some 1:1 natting for that router and was able to establish control connection.
- the only issue remain is that the public internet tunnel is not going up i have done everything on the firewall and allowed any any from wan to the router connection but with no luck.
Firewall : Sonicwall
There is something i am missing here or is my design approach wrong here for the datacenter router.
i have also done some testing when i connect to the router to a normal (4g internet modem ) i am able to form control connection and tunnel is going up with no issue
I have fallowed this guide by cisco:
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/BRKRST-2559.pdf#xd_co_f=MzM1MmViZjgtZmYzMC00YTIxLWIyNTMtZGMzMjE5MTZlZWE4~
Option D.
16 Replies 16
Already done all of the above.
The only issue is with the tunnel it self in datacenter router with the other testing routers.
mpls tunnel is up and running with no issues.
Are vbond connect to vsmart and vmanage via public or via private IP?
