SDWAN Template Error issue
kamlenegi
Level 4
Level 4
Hello All,
Is there any bug or I missing something, not able to push the device template.
WAN Edge: ISR4451-X/K9
ver: 16.10.2
Controller ver: 18.4.302
2-Jan-2020 4:55:12 IST] Configuring device with feature template: Testing
[12-Jan-2020 4:55:12 IST] Generating configuration from template
[12-Jan-2020 4:55:14 IST] Checking and creating device in vManage
[12-Jan-2020 4:55:14 IST] Device is online
[12-Jan-2020 4:55:14 IST] Updating device configuration in vManage
[12-Jan-2020 4:55:16 IST] Pushing configuration to device
[12-Jan-2020 4:55:20 IST] Failed to process device request. Error response : rpc-reply error: <rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="13">
<rpc-error>
<error-type>application</error-type>
<error-tag>operation-failed</error-tag>
<error-severity>error</error-severity>
<error-path xmlns:ios="http://cisco.com/ns/yang/Cisco-IOS-XE-native">
/ios:native/ios:interface/ios:GigabitEthernet[ios:name='0/0/0']/ios:vrf/ios:forwarding
</error-path>
<error-message unknown:lang="en">application error</error-message>
<error-info>
<bad-element>forwarding</bad-element>
</error-info>
</rpc-error>
Kamlesh
dan11
Frequent Visitor
Frequent Visitor
I have been working with Viptela and it seems really sensitive. Can you check if its en (lower case) not EN or something else ?
What config are you trying to push?
saeedek
Level 2
Level 2
try to upgrade Vmanage to version 18.4.4
