SDWAN - vManage API - update device configuration using device templat
lak141516
I would appreciate if someone could help me with the below:
1. The goal is to update the device configuration using the device template - using Python
2. So the step - by- step would be as below as I think:
   - Step1: authentication to vManage, get cookie and token. This is done successfully and able to use these for GET
   - Step2: get the templateID and deviceID (UUID) then POST to /dataservice/template/device/config/input:
          + post function:
    def postRequest(self, mountURL, payload):
        headers = {
            'Content-Type': "application/json",
            #'cache-control': "no-cache",
            'X-XSRF-TOKEN': self.token,
            'Cookie': self.cookie
        url = self.base_url + mountURL
        response = requests.request(
            "POST", url, headers=headers, data=payload, verify=False)
        return response
          + With templateid and UUID collected successfully (as string) - construct the payload:
payload = {"templateId": template_id, "deviceIds": deviceIds, "isEdited": False, "isMasterEdited": False}
          + Generate device input variables by POST to /dataservice/template/device/config/input
mountURL = f'/dataservice/template/device/config/input'
payload = json.dumps(payload)
response = base.postRequest(self, mountURL, payload)
          + However instead of getting 200, the response is 500 with error as below
{"error":{"message":"Server error","details":"vManage server experience an unexpected error,If the problem persists, please contact your administrator for details.","code":"REST0001"}}
          + I tried to run test using the /apidocs/#/Configuration%20-%20Device%20Template/createDeviceInput directly from the vManage - get the same error
          + Log from the vmanage-server.log - showed an exception
07-Feb-2024 10:55:05,397 UTC INFO  [vManage01] [SystemDeviceDAO] (default task-1128) |default| RESOURCE_GROUP=resourceGroup name=global
07-Feb-2024 10:55:07,324 UTC ERROR [GB-LND-LONPWG-vManage01] [RestfulDefaultExceptionMapper] (default task-1128) |default| Uncaught exception thrown by REST
java.lang.ClassCastException: class org.glassfish.json.JsonStringImpl cannot be cast to class javax.json.JsonArray (org.glassfish.json.JsonStringImpl is in unnamed module of loader 'org.glassfish.jakarta.json@1.1.6' @293a5bf6; javax.json.JsonArray is in unnamed module of loader 'javax.json.api@1.1.5' @5b8dfcc1)
        at org.glassfish.json.JsonObjectBuilderImpl$JsonObjectImpl.getJsonArray(JsonObjectBuilderImpl.java:213) ~[jakarta.json-1.1.6.jar!/:1.1.6]
        at com.viptela.vmanage.server.deviceconfig.template.master.MasterTemplateDeviceRestfulResource.createDeviceInput(MasterTemplateDeviceRestfulResource.java:1196) ~[vmanage-server-1.0.0-SNAPSHOT.jar:?]
        at com.viptela.vmanage.server.deviceconfig.template.master.MasterTemplateDeviceRestfulResource$Proxy$_$$_WeldClientProxy.createDeviceInput(Unknown Source) ~[vmanage-server-1.0.0-SNAPSHOT.jar:?]
        at jdk.internal.reflect.GeneratedMethodAccessor260.invoke(Unknown Source) ~[?:?]
        at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
        at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
        at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:535) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:424) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:385) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:356) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:387) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:356) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:329) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
        at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215) ~[resteasy-jaxrs-3.11.2.Final.jar!/:3.11.2.Final]
Would anyone work on this before and can give me some help please? It's strange that even using try now on apidocs also has similar issue.
Thanks in advanced,
Khoa
Dan Frey
The uuid passed to deviceIds in the input api needs to be a list.
# Input
        payload = {"templateId":templateId,"deviceIds":[uuid],"isEdited":False,"isMasterEdited":False}
        api_url = "/template/device/config/input/"
        url = base_url + api_url
        response = requests.post(url=url, headers=headers, data=json.dumps(payload), verify=False)
        print(response.status_code)
        print(response.url)
#        print(response.text)
# Attach Template
        payload = {"deviceTemplateList":[{"templateId":templateId,"device":[{"csv-status":"complete","csv-deviceId":uuid,"csv-deviceIP":systemIp,"csv-host-name":hostName,"csv-templateId":templateId}],"isEdited":False}]}
        payload["deviceTemplateList"][0]["device"][0].update(dataYaml)
        print(json.dumps(payload, indent=4))
        api_url = "/template/device/config/attachcli/"
        print(response.url)
Dan Frey
# Input
        print(response.url)
# Attach Template
        print(response.url)
lak141516
thanks Dan for the advice, you saved my day. Next step for me is to modify the data and push back.
Thanks again.
