vManage and Radius authentication - netadmin group
EminaBrkanic
I am setting windows NPS for vmanage authentication. Configuration is simple and user are authenticated with radius, but they are placed in Basic group. how do I specify netadmin group on radius?
regards
You can configure NPS to send certain radius attributes back depending on the AD group the user authenticating is in.
According to this guide you should send the viptela VSA(41916) "Viptela-Group-Name" attribute back with the "netadmin" string:
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/215349-radius-and-tacacs-based-user-authenticat.html
But this guide, says you should send VSA Cisco "SD-WAN-Group-Name" attribute.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/user-access-authentication.html
So I guess it depends on the version you're running, but you either have to send Viptela-Group-Name: netadmin or SD-WAN-Group-Name: netadmin back as an authorization result.
Now it's been a while since I worked with NPS, but if you search for a guide on custom attributes or vendor-specific-attributes you should be able to find a resource that explains the config on NPS side.
Please mark helpful answers & solutions
EminaBrkanic
I did as you suggested, but it didn't work. I open tac case for this and finally solved it. On NPS you need to specify vendor-specific-attributes like on the picture.
