I'm trying to resolve an issue related to a Configuration failure for SMC. What are the possible solutions for below issue?
{"successful":false,"details":"exit code: 1
ElementIDs without results: aide, auditLogDestination, configBackup, dns, dnsCache, dodin, externalServices, fips, host, internetProxy, ldapSetup, localResolution, networkInterfaces, ntp, openingMessage, passwordPolicy, sessionTimeout, smtp, snmpAgent, ssh, sso, tlsApplianceIdentity, tlsClientIdentities, trustStore
---STDERR---
ERROR! Attempted to execute \"./ansible-inventory.py\" as inventory script: Inventory script (./ansible-inventory.py) had an execution error: /usr/local/lib/python2.7/dist-packages/urllib3/connectionpool.py:986:
InsecureRequestWarning: Unverified HTTPS request is being made to host '10.x.x.x'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
InsecureRequestWarning,/usr/local/lib/python2.7/dist-packages/urllib3/connectionpool.py:986: InsecureRequestWarning: Unverified HTTPS request is being made to host '10.x.x.x'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
InsecureRequestWarning,Traceback (most recent call last):
File \"/opt/service/ansible/ansible-inventory.py\", line 48, in
\"config\": fetch_configuration(),
File \"/opt/service/ansible/ansible-inventory.py\", line 37, in fetch_configuration
raise Exception(\"Unable to fetch configuration from appliance \" + os.environ['APPLIANCE_ID'], r)
Exception: ('Unable to fetch configuration from appliance 8xxxxxx8-3xx1-4xxx-xxx2-xxxxxxxx17xx', )
","elementResults":{}}
