Jitendriya Athavale
    Upgrading ASA or for that matter  any device is really a very simple procedure, however sometimes due to  some very simple yet difficult to diagnose issues the upgrade process  can go for unexpectedly long
    This documents hopes to identify some common issues which we encounter when performing upgrades
    Copy TFTP flash fails midway through the image load
    This  happens usually when there is network congestion and packets get lost  in between tftp server and asa, also remember tftp is an unreliable  protocol which works on udp port 69
    Resolution: Connect the tftp server direcly to asa or through a switch
    tftp server ----------------switch-----------asa
    Also try not to upload image over vpn tunnel using tftp
    if the number of hops are more then it is suggested that you use ftp to upload files to flash
    https://supportforums.cisco.com/docs/DOC-12658
    %Error opening disk0:/asa822-k8.bin (Read-only file system)
    we get this error usually if there is something wrong with the flash, probably the flash might be corrupted
    Resolution: issue the command "fsck flash:" and/or "format flash:"
    while the first one is harmless, be informed that the second command "format flash:" erases the entire flash and this means the image and the startup config, so if you are planning to format the flash make sure that the firewall does not reboot under any circumstance as this will force your firewall into rommon mode when it boots because there will be no image in the flash
    so the option that you have here is change the boot system from disk0 to tftp server so that the asa boots from tftp server even if it relaods by chance (due to power outage or something like that), also make sure that you have a back up of your config handy to deal with such situations
    In most cases formatting flash should help and you can copy back the images and config files.
    If it is a standalone firewall that you have (without failover), it is recommended that you seek advise from TAC before you proceed towards formatting flash
    While doing from asdm  - Error occurred in performing File Transfer - "Error writing request body to server"
    WorkAround: we have seen this error few times when file transfer was tried from asdm, there is no know cause for this but a possible work around is to try using scp or tftp to upload the file and this is known to have worked in most cases.
    Unspecified error in tftp –
    we get this error mainly due to network related problems, either it could be connectvity issue or could be that there is a firewall blocking the tftp request on the server or a server config issue like server might not be configured to request files or at times i have seen that few servers have trouble transferring large files
    Resolution: Check connectivity, disable any firewall/antivirus/hips software on the PC acting as tftp server. Also try to use another tftp server. In my experience tftpd32 has worked for me in almost all scenarios.
    Error writing disk0:/asa***-k8.bin (Cannot allocate memory)
    The ASA requires one full memory block be available to buffer the entire image before writing it to flash. Probably there is not a block available to accommodate your image . The memory usage is directly related to the features you have enabled on the box, which will load each time the box is loaded.
    Resolution: You can reduce your memory usage by disabling features that you are not currently using like threat detection. Upgrading from rommon also helps in such scenario's. Just be aware as to which features you are disabling and make sure you undersatnd the impact that disabling any feature will have on your network
