laxmanstha
Community Member
Hi all,
I am configuring the DUAL HUB Dual Cloud DMVPN topology using ospf.  we have one L2 link and one L3 link at each hub and each brach router have  two L2 links and two L3 links for redundancy to achieve HA.
Attached is the configuration of Hubs and a spoke router, the problem i am facing is that
1>The ospf in DMVPN cloud flaps every time the dead timer expires.
2>When the primary Hub is shut down the job is overtaken by secondary hub but when primary hub comes back, the ospf in primary hub does not establish immediately(take long time even an hour).
laxmanstha
Community Member
laxmanstha
Community Member
Above is the topology diagram and following is the configuration.
HUB 1:-
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key CUST@#vpn4all address 0.0.0.0
crypto ipsec transform-set CUSTSET esp-3des esp-sha-hmac
crypto ipsec profile CUST-PROFILE
set transform-set CUSTSET
interface Loopback0
description "LOOPBACK"
ip address 192.168.254.254 255.255.255.255
ip ospf 10 area 0
interface Tunnel0
description "CUST-L2-TUNNEL"
bandwidth 4000
ip address 10.10.10.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication CUSTVPN
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip tcp adjust-mss 1360
ip ospf network point-to-multipoint
ip ospf cost 100
ip ospf 10 area 1
tunnel source 172.16.10.20
tunnel mode gre multipoint
tunnel protection ipsec profile CUST-PROFILE
interface Tunnel1
description "CUST-L3-TUNNEL"
bandwidth 3000
ip address 10.10.11.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 100001
ip ospf cost 200
ip ospf 10 area 1
tunnel source xxx.xxx.205.142
interface GigabitEthernet0/0
description "ISP L2"
ip address 172.16.10.20 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description "ISP L3"
ip address xxx.xxx.205.142 255.255.255.0
duplex auto
speed auto
interface Vlan10
description "CUST-BTR-LAN"
ip address 172.16.16.3 255.255.255.248
ip ospf 10 area 0
vrrp 1 ip 172.16.16.1
vrrp 1 timers advertise 3
vrrp 1 timers learn
vrrp 1 priority 120
vrrp 1 authentication admin123
router ospf 10
router-id 192.168.254.254
area 1 stub no-summary
passive-interface default
no passive-interface Loopback0
no passive-interface Tunnel0
no passive-interface Tunnel1
no passive-interface Vlan10
ip forward-protocol nd
HUB 2:-
encr 3des
group 2
interface Loopback0
ip address 192.168.254.253 255.255.255.255
ip ospf 10 area 0
interface Tunnel2
description "CUST02-L2-TUNNEL"
bandwidth 2000
ip address 10.10.12.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 100002
ip ospf cost 300
ip ospf 10 area 1
tunnel source 172.16.11.20
interface Tunnel3
description "CUST02-L3-TUNNEL"
bandwidth 1000
ip address 10.10.13.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 100003
ip ospf cost 400
ip ospf 10 area 1
tunnel source xxx.xxx.217.239
ip address 172.16.11.20 255.255.255.0
duplex auto
speed auto
ip address xxx.xxx.217.239 255.255.255.0
duplex auto
speed auto
interface Vlan10
ip address 172.16.16.4 255.255.255.248
ip ospf 10 area 0
vrrp 1 timers learn
vrrp 1 priority 110
router ospf 10
router-id 192.168.254.253
no passive-interface Tunnel2
no passive-interface Tunnel3
SPOKE:-
encr 3des
group 2
crypto isakmp key CUST@#vpn4all address 0.0.0.0 0.0.0.0
crypto ipsec profile CUST_PROFILE
interface Loopback0
ip address 192.168.254.246 255.255.255.255
ip ospf 10 area 1
interface Tunnel0
description ***L2-Tunnel***
bandwidth 4000
ip address 10.10.10.7 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.10.10.1 172.16.10.20
ip nhrp nhs 10.10.10.1
ip ospf cost 100
ip ospf 10 area 1
tunnel source 172.16.10.15
tunnel protection ipsec profile CUST_PROFILE
interface Tunnel1
description ***L3-Tunnel***
bandwidth 3000
ip address 10.10.11.7 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.10.11.1 xxx.xxx.205.142
ip nhrp nhs 10.10.11.1
ip ospf cost 200
ip ospf 10 area 1
tunnel source xxx.xx.43.184
interface Tunnel2
description ***L2-Tunnel 2ND***
bandwidth 2000
ip address 10.10.12.7 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.10.12.1 172.16.11.20
ip nhrp nhs 10.10.12.1
ip ospf cost 300
ip ospf 10 area 1
tunnel source 172.16.11.15
interface Tunnel3
description ***L3-Tunnel 2ND***
bandwidth 1000
ip address 10.10.13.7 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.10.13.1 xxx.xxx.217.239
ip nhrp nhs 10.10.13.1
ip ospf cost 400
ip ospf 10 area 1
tunnel source xxx.xxx.223.48
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1304
description "ISP L2 1ST"
encapsulation dot1Q 1304
ip address 172.16.10.15 255.255.255.0
no cdp enable
interface GigabitEthernet0/0.1305
description "ISP L2 2ND"
encapsulation dot1Q 1305
ip address 172.16.11.15 255.255.255.0
no cdp enable
ip address xxx.xx.43.184 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/0
description description "ISP L3 2ND"
ip address xxx.xxx.223.48 255.255.255.0
duplex auto
speed 100
interface GigabitEthernet0/1/0
description "CUSTSID LAN"
switchport access vlan 10
no ip address
interface Vlan10
ip address 192.168.143.1 255.255.255.0
ip ospf 10 area 1
router ospf 10
router-id 192.168.254.246
laxmanstha
Community Member
Hi all,
I have identified the ospf flap problem, the reason behind the flap was that the HUBs are not replying multicast hello requested by spoke, which was solved by changing the "ip nhrp map multicast dynamic" at spoke to "ip nhrp map multicast hub-physical-ip-address"
changes made in spoke are:-
int tun 0
no ip nhrp map multicast dynamic
ip nhrp map multicast 172.16.10.20
int tun 1
ip nhrp map multicast xxx.xxx.205.142
int tun 2
ip nhrp map multicast 172.16.11.20
int tun 3
ip nhrp map multicast xxx.xxx.217.239
But problem 2 is still there, any suggestions and solutions are highly appreciated.
laxmanstha
Community Member
Hi all,
The problem has been solved now by adding crypto keepalive timer and if-state nhrp at spokes. So finally working configuration as as follows.  ENJOY!!!!!
HUB 1:-
encr 3des
group 2
crypto isakmp keepalive 30 5
mode transport
interface Loopback0
ip ospf 10 area 0
interface Tunnel0
bandwidth 4000
no ip redirects
ip mtu 1400
ip ospf cost 100
ip ospf 10 area 1
interface Tunnel1
bandwidth 3000
no ip redirects
ip mtu 1400
ip ospf cost 200
ip ospf 10 area 1
duplex auto
speed auto
duplex auto
speed auto
interface Vlan10
ip ospf 10 area 0
vrrp 1 timers learn
vrrp 1 priority 120
router ospf 10
HUB 2:-
encr 3des
group 2
mode transport
interface Loopback0
ip ospf 10 area 0
interface Tunnel2
bandwidth 2000
no ip redirects
ip mtu 1400
ip ospf cost 300
ip ospf 10 area 1
interface Tunnel3
bandwidth 1000
no ip redirects
ip mtu 1400
ip ospf cost 400
ip ospf 10 area 1
duplex auto
speed auto
duplex auto
speed auto
interface Vlan10
ip ospf 10 area 0
vrrp 1 timers learn
vrrp 1 priority 110
router ospf 10
SPOKE:-
encr 3des
group 2
mode transport
interface Loopback0
ip ospf 10 area 1
interface Tunnel0
bandwidth 4000
no ip redirects
ip mtu 1400
ip ospf cost 100
ip ospf 10 area 1
if-state nhrp
interface Tunnel1
bandwidth 3000
no ip redirects
ip mtu 1400
ip ospf cost 200
ip ospf 10 area 1
if-state nhrp
interface Tunnel2
bandwidth 2000
no ip redirects
ip mtu 1400
ip ospf cost 300
ip ospf 10 area 1
if-state nhrp
interface Tunnel3
bandwidth 1000
no ip redirects
ip mtu 1400
ip ospf cost 400
ip ospf 10 area 1
if-state nhrp
no ip address
duplex auto
speed auto
no cdp enable
no cdp enable
duplex auto
speed auto
duplex auto
speed 100
no ip address
interface Vlan10
ip ospf 10 area 1
router ospf 10
