Anupam Pavithran
Problem:
SNMP on FDM was introduced in version 6.7. As of now, we only have the option to push via API. The current method is time-consuming, and knowledge of API is needed.
Here is the current guide we have.
https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/216551-configure-and-troubleshoot-snmp-on-firep.html
Solution
@Dinesh Verma  and I created a script that automates the entire workflow using Python. You only need to enter the details pertaining to SNMPv2/SNMPv3; the script takes care of everything else. The script is available in the following GitHub repository.
https://github.com/anupamx47/FDM-SNMP/tree/main
1) Preparation:
1.Download the Script:
  • Go to the script's GitHub page: fdm-snmp.py.
  • Click the "Download Zip" button, under "code" to download the Python script to your computer.
2.Install Python:
  • Make sure you have Python installed on your computer. You can download and install the latest version of Python from the official Python website: Python Downloads. Follow the installation instructions for your operating system.
3.Install Required Dependencies:
  • Open a command prompt or terminal.
  • Navigate to the directory where you downloaded the script.
  • Run the following command to install the necessary dependencies:
    pip3 install -r requirements.txt
4.Execute the Script:
  • Navigate to the directory where you downloaded the script using the cd command.
  • Run the script using Python:
    python3 fdm-snmp.py
2) Create SNMPv2 Host
C:\Users\anpavith\OneDrive\Desktop\scripts\FDM-SNMP> python3 fdm-snmp.py
# CONFIGURE SNMP ON FDM #
Enter the device IP address: 10.106.55.56
Enter the username of the FTD: admin
Enter the password of the FTD:
Auth-Status code is 200
Successfully Authenticated
Would you like to configure (1) SNMPv2 or (2) SNMPv3 : 1
Enter the SNMP Server object name : solar22
Enter the SNMP Server object IP : 22.22.22.22
Enter SNMPv2 community string : cisco123
1 diagnostic Management0/0
2 dmz GigabitEthernet0/2
3 inside GigabitEthernet0/1
4 outside GigabitEthernet0/0
Select the interface (Integer value only) : 4
Enter SNMP host object name : snmp22
Successfully Created, please deploy and check SNMP config
3) Create SNMPv3 Host along with SNMPv3 user
C:\Users\anpavith\OneDrive\Desktop\scripts\FDM-SNMP> python3 .\fdm-snmp.py
Would you like to configure (1) SNMPv2 or (2) SNMPv3 : 2
Enter the SNMP Server object name : solar21
Enter the SNMP Server object IP : 21.21.21.21
Enter SNMPv3 username : cisco21
Enter Security Level => Options ['AUTH', 'NOAUTH', 'PRIV'] : PRIV
Enter authentication Algorithm => Options ['SHA', 'SHA256'] : SHA
Enter authentication password : cisco123
Enter encryption Algorithm => Options ['AES128', 'AES192', 'AES256', '3DES'] : AES128
Enter encryption password : cisco123
Enter SNMP host object name : host21
Please use the script and provide us with any feedback.
Marvin Rhoads
@Anupam Pavithran and @Dinesh Verma thanks so much for creating this useful script.
However, I found that it does not return the diagnostic Management1/1 interface as an option. (This is when I attempt to use it on a Firepower 2140 HA pair running FTD 6.7 with FDM management). It mostly returns currently unconfigured interfaces on the target FTD. Eth1/3 is a configured interface and Eth1/13-16 are assigned to portchannels (13-14 = Po1 and 15-16 = Po2)
Here is my output:
Enter the device IP address: <redacted>
Enter the SNMP Server object name : prime
Enter the SNMP Server object IP : <redacted>
1 Ethernet1/14
2 Ethernet1/11
3 Ethernet1/8
4 Ethernet1/10
5 Ethernet1/7
6 Ethernet1/9
7 Ethernet1/4
8 Ethernet1/5
9 Ethernet1/2
10 Ethernet1/6
(Note I also had to install the prerequisite requests module in my local python environment. "python -m pip install requests")
Anupam Pavithran
Hi Marvin,
Thanks for testing, I'll review the script and update.
davebush
HI Anupam - I'm getting the following message when I try to use the script on my FP1010 running 6.7.0-65 with snort
I'm not sure if it matters, but Ethernet1/2-1/8 are all set up as switch ports. They are all set up as trunk ports, with Vlan1 (my legacy network VLAN) set as the native VLAN, and they also have access to VLANS 8 (core), 16 (userdevices), 24 (iot) and 32 (guestwifi) as well. For SNMP, they'd be talking to my Stealthwatch SMC on VLAN 8.
Here's the output from me running your script:
Enter the device IP address: 172.16.8.1
Enter the SNMP Server object name : snmpserver
Enter the SNMP Server object IP : 172.16.10.0
1 diagnostic Management1/1
2 outside Ethernet1/1
3 None Ethernet1/4
4 None Ethernet1/7
5 None Ethernet1/6
6 None Ethernet1/2
7 None Ethernet1/5
8 None Ethernet1/8
9 None Ethernet1/3
Select the interface (Integer value only) : 6
Enter SNMP host object name : snmphost
{'error': {'severity': 'ERROR', 'key': 'General', 'messages': [{'description': 'The server understands the content type of the request entity and the syntax of the request entity is correct but was unable to process the contained instructions', 'code': None, 'location': None}, {'description': 'InvalidTypeIdException: Missing type id when trying to resolve subtype of [simple type, SNMPSecurityConfiguration]: missing type id property \'type\' (for POJO property \'securityConfiguration\')\n at [Source: (UnclosableInputStream); line: 1, column: 374] (through reference chain: SNMPHost["securityConfiguration"])', 'code': None, 'location': None}]}}
Anupam Pavithran
@Marvin Rhoads and @davebush, we have fixed both the issues in the new build which is attached "Release_1.2.zip".
Thanks a lot for testing and sharing your valuable feedback
- Anupam
-@Dinesh Verma
Anupam Pavithran
@Marvin Rhoads Just updated the attachment, you were way too fast 🙂
davebush
Hi @Anupam Pavithran - Looks like 1.2 has removed all options except the management interface and the outside interface.
davebush@lc19:~$ python3 fdm-snmp.py
Enter SNMPv2 community string : public
Ideally, I'd like to have this tied to Vlan8 which has the name core on my FP1010.
I'm happy to do a Webex if you'd like to get on my FP1010 and take a look. Just reach out to me on Teams.
Marvin Rhoads
Thanks for v1.2. I was able to use the updated script to successfully associate my snmp-server with the diagnostic interface.
I did need to go into FDM and then add an address for diagnostic interface (must be in same subnet as management interface) as well as a route for the diagnostic interface to the SNMP server address. (The route assigned to management for the clish dosen't also include traffic from the diagnostic interface in the LINA subsystem.) Once I did that I was able to successfully add the FTD device to my Cisco Prime Infrastructure server.
Now I need to work on generating some syslog messages. My goal is to have Prime send an email alert when a certain severity of log message is received from FTD (e.g. a firewall failover).
Anupam Pavithran
@davebush Thanks for testing, as seen over WebEx vlan interfaces needs to be added too.
We'll include the same in the next build.
-Anupam
Anupam Pavithran
@Marvin Rhoads Sounds great! Again, thanks for testing 🙂
davebush
Thanks again, @Anupam Pavithran ! I'm glad we were able to get this working on my VLANs last night. I can confirm that after the work we did last night, SMC SNMP.pngmy Stealthwatch Management Console was able to successfully poll my FP1010.
Is there a way for me to do it via API explorer?
Anupam Pavithran
I am trying to use it with FTD 6.6.1
I get the following
I see that it does not bring the interfaces
Is it because of the version or sth else?
Thanks and regards,
Konstantinos
Anupam Pavithran
Hi Konstantinos,
The script is applicable for version FTD 6.7 and above.
-Anupam
MSJ1
Level 5
Level 5
I have a FP1010 managed using FDM. Need to configure SNMP on it. Version is 6.7.0-65. Have couple of questions as below
---- Step 3: Make sure proper permission is given to script to execute (This applies specifically if you're executing script from linux machine) --- If I use Windows Machine Permission perspective what I need to check  ?
---- @Marvin Rhoads
Can you explain a little more for your below note  ? I see my management Interface and diagnostic interface is same. Hence I do not think i will fall into below situation. Route perspective how can I check that from diagnostic/management Interface it can reach SNMP Server ? Note that I only have OutSide Interface and Mgmt/Diag Interface , other Interfaces is not connected yet which is part of Vlan 1.
"I did need to go into FDM and then add an address for diagnostic interface (must be in same subnet as management interface) as well as a route for the diagnostic interface to the SNMP server address. (The route assigned to management for the clish dosen't also include traffic from the diagnostic interface in the LINA subsystem.)"
