TCC_2
Level 10
Level 10
Core issue
Configure static Port Address Translation (PAT) on the PIX.
Resolution
Starting with PIX Software version 6.0, the PIX can be configured to translate ports destined to a single global IP address to multiple internal servers.
One place this would be useful is if you only have a single IP address available from your ISP, but your web server is on a different box than your mail server. You can use port redirection (static PAT) to accomplish this.
Example
Address available from ISP: 209.165.201.5
Mail Server IP Address: 10.10.10.5
Web Server IP Address: 10.10.10.6
PIX commands are shown below.
  static (inside,outside) tcp 209.165.201.5 25 10.10.10.5 25 netmask 255.255.255.255
  static (inside,outside) tcp 209.165.201.5 80 10.10.10.6 80 netmask 255.255.255.255
     !--- Now that the port redirection is defined, we need
     !--- to allow inbound access via an access list.
  access-list inbound permit tcp any host 209.165.201.5 eq 25
  access-list inbound permit tcp any host 209.165.201.5 eq 80
  access-group inbound in interface outside
     !--- Finally, if those two servers also need to initiate
     !--- connections outbound, then we need to do PAT on
     !--- them to the static address.
  nat (inside) 1 10.10.10.5 255.255.255.255
  nat (inside) 1 10.10.10.6 255.255.255.255
  global (outside) 1 209.165.201.5
For more information and configuration examples, see Port Redirection with Statics.
