athukral
Introduction: This document describes the process of bypassing an inspect.
Prerequisites:
1.       FWSM/ASA
2.       FWSM 3.X/PIX or ASA 7.X and above
Sample
This is just a quick example of how to bypass an inspect using the modular policy framework for the ASA/FWSM 3.X/PIX 7.X and above
access-list acl_skinny_inspect deny tcp host 10.10.10.1 any eq 2000
access-list acl_skinny_inspect permit tcp any any eq 2000
class-map inspect_skinny
match access-list acl_skinny_inspect
policy-map global_policy
class inspection_default
  no inspect skinny
  inspect skinny
service-policy global_policy global
The above example will allow the skinny inspect to be bypasses on port 2000 for host 10.10.10.1
A quick way to see what traffic inspections are enabled for in the inspection_default class is to run the command like below:
ASA# conf t
ASA(config)# class-map inspection_default
ASA(config-cmap)# match ?
mpf-class-map mode commands/options:
  access-list                 Match an Access List
  any                         Match any packet
  default-inspection-traffic  Match default inspection traffic:
                              ctiqbe----tcp--2748      dns-------udp--53
                              ftp-------tcp--21        gtp-------udp--2123,3386
                              h323-h225-tcp--1720      h323-ras--udp--1718-1719
                              http------tcp--80        icmp------icmp
                              ils-------tcp--389       ip-options-----rsvp
                              mgcp------udp--2427,2727 netbios---udp--137-138
                              radius-acct----udp--1646 rpc-------udp--111
                              rsh-------tcp--514       rtsp------tcp--554
                              sip-------tcp--5060      sip-------udp--5060
                              skinny----tcp--2000      smtp------tcp--25
                              sqlnet----tcp--1521      tftp------udp--69
                              waas------tcp--1-65535   xdmcp-----udp--177
  dscp                        Match IP DSCP (DiffServ CodePoints)
  flow                        Flow based Policy
  port                        Match TCP/UDP port(s)
  precedence                  Match IP precedence
  rtp                         Match RTP port numbers
  tunnel-group                Match a Tunnel Group
ASA(config-cmap)#
Show Command To Verfiy
ciscoasa# sh service-policy
Global policy:
  Service-policy: global_policy
Class-map: inspect_skinny
      Inspect: skinny , packet 0, drop 0, reset-drop 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
Hence with this command you can verify on how many packets are dropped, reset-drop etc.
Hope this quick sample is informative and helpful.
