To control extended Radio transmissions use the LMR timeout voice port command to adjust the time from 0-30 minutes.
timeout ptt
To specify a maximum time for transmitting or receiving a voice packet, use the timeout ptt command
in voice-port configuration mode. To return to the default, use the no form of this command.
timeout ptt {rcv | xmt} minutes
no timeout ptt {rcv | xmt} minutes
Syntax Description
Defaults minutes: 0 minutes
Command Modes Voice-port configuration
Command History
Usage Guidelines The timeout ptt command is available on an ear and mouth (E&M) analog or digital voice port only if
the signal type for that port is Land Mobile Radio (LMR). The purpose of this command is to limit
extended radio transmission. When the time limit configured with this command expires, the radio
transmitter unkeys, so that listeners on the channel cannot hear the speaker, even if the speaker continues
to talk. When the speaker unkeys the radio, the timer is reactivated.
Examples The following example specifies a maximum time of 10 minutes for transmitting a voice packet:
voice-port 1/0/0
timeout ptt xmt 10
rcv Applies the specified time limit to the reception of voice packets.
xmt Applies the specified time limit to the transmission of voice packets.
minutes Maximum time, in minutes, allowed for transmitting or receiving a voice
packet. Range is integers from 1 to 30.
Release Modification
12.3(4)XD This command was introduced.
12.3(7)T This command was integrated into Cisco IOS Release 12.3(7)T.
12.3(14)T This command was implemented on the Cisco 2800 series and Cisco 3800
series.
12.4(2)T This command was integrated into Cisco IOS Release 12.4(2)
