thomas
This document contains ISE 2.0 installation details for Cisco platform exchange grid (pxGrid) and associated SDK and includes sample pxGrid scripts. These can be run in a non-802.1X or 802.1X environment.
For more information on development with pxGrid please look at the environment in Cisco Devnet at Learning pxGrid
Utilizing the devnet sandbox environment for basic testing
  • For vendor engagements please visit cisco.com/go/csta
  • For customers integrating directly please use Cisco TAC.
pxGrid ISE 2.0 new features:
  • Dynamic Topics–contextual information can be shared between the registered/subscribed pxGrid clients. pxGrid clients can act as publisher or subscribers to publish or consume this information. Please note that ISE will not be able to consume this information.
  • Adaptive Network Control (ANC) Policy- provides 3rd party applications or Cisco Security Solutions to customize mitigation actions: quarantine, remediation, provisioning, port bounce, port shut from an ISE policy or pxGrid ANC query script.
  • Publish SXP Bindings- enables subscribers to get receive IP, SGT-Tag, Source, Peer Sequence information The reader will use Radius Simulator for non-802.1X environments. The pxGrid session attributes such as posture
    information, endpoint device require an 802.1X environment for testing.
    The pxGrid ISE 2.0 features require an 802.1X environment for testing. Additionally, TrustSec compatibility will be required on network devices if testing SXP is planned.
The documentation is attached in devnet as Configure and Test Integration with Cisco pxGrid using Cisco Identity Services Engine (ISE) 2.0
x00008037
Hi , Is it possible for any 3rd party application to invoke PxGrid ANC API.
For example we want Azure Sentinal to be bale to invoke ANC API won ISE to quarantine endpoints
