jkurunczi
I am testing a DSL business line with a PIX 525 firewall.
I have an Internal network of 197.39.101.0/26. (The IP addresses for the inside and outside networks were changed.)
The external IP address is dynamically assigned from the ISP.
I created a nat for the inside network and used a global command for the outside.
Then I statically assigned an external IP to an internal IP.
I opened up all tcp, upd, icmp, ip traffic and port 80 and 7047.
From the Internet I would like to get to test the following:
1) ping 68.39.213.197
2) trace route 68.39.213.197
3) http://68.39.213.197:7047
4) http://68.39.213.197
None of the above seem to be working.
I have attached the configuration file.
Can anyone see any problems with this configuration?
Can anyone help?
Your help would be greatly appreciated. Thank you.
PIX Version 8.0(4)
hostname fw2
domain-name testing.com
names
dns-guard
interface Ethernet0
nameif outside
security-level 0
pppoe client vpdn group test-pppoe-att
ip address pppoe setroute
interface Ethernet1
nameif inside
security-level 100
ip address 197.39.101.33 255.255.255.192 standby 197.39.101.34
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
description STATE Failover Interface
interface Ethernet4
nameif management
security-level 100
ip address 192.168.100.1 255.255.255.0 standby 192.168.100.2
management-only
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns domain-lookup outside
dns domain-lookup inside
dns domain-lookup management
dns server-group DefaultDNS
access-list OUT_IN extended permit tcp any host 68.39.213.197 eq www
access-list OUT_IN extended permit tcp any host 68.39.213.197 eq 7047
access-list OUT_IN extended permit tcp any any
access-list OUT_IN extended permit udp any any
access-list OUT_IN extended permit icmp any any
access-list OUT_IN extended permit ip any any
access-list 101 extended permit tcp any any
access-list 101 extended permit udp any any
access-list 101 extended permit icmp any any
access-list 101 extended permit ip any any
pager lines 24
logging enable
logging timestamp
logging buffer-size 1048576
logging trap errors
logging history errors
logging asdm errors
logging host inside 197.39.101.27
logging permit-hostdown
mtu outside 1500
mtu inside 1500
mtu management 1500
failover
failover link failover Ethernet3
failover interface ip failover 192.168.6.254 255.255.255.0 standby 192.168.6.253
no monitor-interface outside
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-61551.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 197.39.101.0 255.255.255.0
static (inside,outside) 68.39.213.197 197.39.101.87 netmask 255.255.255.255
access-group OUT_IN in interface outside
access-group 101 in interface inside
route inside 197.39.101.0 255.255.255.0 197.39.101.62 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 197.39.101.0 255.255.255.0 inside
http 192.168.100.0 255.255.255.0 management
snmp-server host inside 197.39.101.25 community testmgmt version 2c
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 197.39.101.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
vpdn group test-pppoe-att request dialout pppoe
vpdn group test-pppoe-att localname testing@att.net
vpdn group test-pppoe-att ppp authentication pap
vpdn username testing@att.net password *****************************
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 197.39.101.20 source inside prefer
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:be07d15845e099d1c208c0e6a1360176
: end
