minkumar
Introduction
This document provides an example on how to configure Remote Access VPN on  ASA and do the authentication using ACS as Radius server
Prerequisites
ACS  should have ASA added as a AAA client with correct secret key. Both  should be reachable. Please take up back up of ASA before adding any  configuration of the AAA.
Components Used
1. ASA 8.2
2. ACS 5.2 (as RADIUS)
Configuration Remote Access VPN on ASA
Interface configuration
hostname(config)# interface ethernet0
hostname(config-if)# ip address 192.168.1.5 255.255.0.0
hostname(config-if)# nameif outside
hostname(config)# no shutdown
hostname(config)# interface ethernet1
hostname(config-if)# ip address 192.168.1.4 255.255.0.0
hostname(config-if)# nameif inside
Configuring ISAKMP Policy and Enabling ISAKMP on the Outside Interface
hostname(config)# isakmp policy 1 authentication pre-share
hostname(config)# isakmp policy 1 encryption 3des
hostname(config)# isakmp policy 1 hash sha
hostname(config)# isakmp policy 1 group 2
hostname(config)# isakmp policy 1 lifetime 43200
hostname(config)# isakmp enable outside
Configuring an Address Pool
hostname(config)# ip local pool testpool 192.168.0.10-192.168.0.15
Adding a User
hostname(config)# username testuser password 12345678
Creating a Transform Set
hostname(config)# crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
Creating a Tunnel group
hostname(config)# tunnel-group testgroup type ipsec-ra
hostname(config)# tunnel-group testgroup general-attributes
hostname(config-general)# address-pool testpool
hostname(config)# tunnel-group testgroup ipsec-attributes
hostname(config-ipsec)# pre-shared-key 44kkaol59636jnfx
Creating a Dynamic crypto map
hostname(config)# crypto dynamic-map dyn1 1 set transform-set FirstSethostname(config)# crypto dynamic-map dyn1 1 set reverse-route
Creating a Crypto Map Entry to Use the Dynamic Crypto Map
hostname(config)# crypto map mymap 1 ipsec-isakmp dynamic dyn1
hostname(config)# crypto map mymap interface outside
Configuring Radius server on the ASA
ciscoasa(config)# aaa-server RADIUS protocol RADIUS
ciscoasa(config-aaa-server-group)# exit
ciscoasa(config)# aaa-server RADIUS (inside) host 192.168.1.2
ciscoasa(config-aaa-server-host)# key CISCO123
ciscoasa(config-aaa-server-host)# exit
Assigning RADIUS server under tunnel group
ciscoasa(config)#tunnel-group testgroup general-attributes
ciscoasa(config-tunnel-general)#authentication-server-group RADIUS
Adding ASA as a client on the ACS server
Add the ip address of the ASA on the ACS which is 192.168.1.4 and shared secret key which is CISCO123:
Creating a rule in Default Network Access policy
1.select an identity store (means define whether users are internal to ACS or in external database)
2. Authorization policy:  (allowing permit or deny access)
Verification
Test with CLI:
You can use the test command on the command line in order to test your AAA setup. A test  request is sent to the AAA server, and the result appears on the command line.
ciscoasa#test aaa-server authentication RADIUS host 192.168.1.2
   username cisco password cisco123INFO: Attempting Authentication test to IP address <192.168.1.2>
   (timeout: 12 seconds)
INFO: Authentication Successful
Troubleshoot
Run the following command to see the debugs:
  • #Debug Radius
  • #Debug aaa common 255
Scenario 2
Problem:
ACS 5.5 secondary registration - Registration failed due to Invalid Certificate
Solution
When you enable Trust Communication on your primary and secondary ACS instance, and you register the secondary instance with the primary, both the primary and secondary instance check the CA and server certificates of each other. After the certificates are verified:
– If the certificates in both the primary and secondary ACS instances are valid certificates, the instances establish a secure tunnel between them and register the secondary instance to the primary.
I don't think it supports self-signed certificate however you can try installing the self-signed certificate of Primary in the secondary instance CA store and self signed certificate of secondary in the primary instance CA store.
Please post comments if there are any queries and rate if useful.
