Do you mean
CCA - Generating certificates for longer period using openssl
by Level 7 ‎07-05-2010 02:12 PM - edited ‎03-08-2019 06:33 PM
How to generate self-signed certificates for period longer than 90 days.
4.8 now issues self-signed certificates for 5 years!
by Level 1
on ‎08-05-2010 06:55 AM
Hi Faisal,
friend, I made everything that you detailed in your PDF and everything works fine, after the first time.
these instructions is fully helpful.
Thanks a lot.
by Level 1
on ‎08-06-2010 07:29 AM
Faisal,
please, i have a doubt about that certificate with openssl.
I could see on my old CAS on "X509 Certificate" tab that appears "ROOT CA Certificate" together with CCA Server certificate and private key but after I've generated a certificate with openssl my new CAS show me just CCA Server certificate and private key.
Why does root ca not appear?
thanks
for me SSL certificate is a litlle confuse, if you have any links to understand about it.
thanks a lot
by Level 7
on ‎08-13-2010 04:35 AM
Daniel,
Because the identity certificate (certificate for the device) is the root certificate itself! It's a true self-signed certificate, and hence doesn't list itself as a root.
HTH,
Faisal
by Level 1
on ‎08-13-2010 03:01 PM
Ok Faisal, thanks for you reply..
today i am trying to create a certificate from our microsoft server 2003 but without success!! do you know any material or guide that can I use to replace this certificate to microsoft certificate using NAC?
I was trying to export my certificate with my Private key and our server we try to use the webserver type but the 2003 server returns on *.cer file.
thanks a lot
