Blue_Bird
        DMVPN Phase-3 with IPSec IKEv2
Introduction
Lab Topology
DMVPN Phase-3 Configuration
IPsec IKEv2 Configuration
Verification
Introduction
The final phase of DMVPN changes the way NHRP operates. The spoke routers no longer need specific routes to reach remote spokes and it doesn't matter what the next hop IP address is. When a spoke router wants to reach a remote spoke, they will forward their traffic to the hub.
 When the hub receives the traffic, it will realize that another spoke is the destination and it will then send a NHRP redirect to both spokes. When the spokes receive the NHRP redirect, they will both send a NHRP resolution to figure out each other's NBMA IP addresses. The spoke routers will then install a new entry in the routing table so that they can reach each other directly.
Assuming that all routers are configured with  Underlay. First we are going to see DMVPN Phase 3 (Overlay) Configuration. Since traffic is not encrypted by default with DMVPN, we are going to implement IKEv2 IPsec to encrypt the traffic passing through the DMVPN tunnels and secure them.
Lab Topology
DMVPN Configuration
Hub Configuration
R1(config)#interface Tunnel 0
R1(config-if)#ip address 192.168.1.1 255.255.255.0
R1(config-if)#no ip redirects
R1(config-if)#tunnel mode gre multipoint
R1(config-if)#tunnel source Ethernet0/0
R1(config-if)#ip nhrp authentication vpn
R1(config-if)#ip nhrp map multicast dynamic
R1(config-if)#ip nhrp network-id 1
R1(config-if)#ip nhrp redirect
R1(config-if)#exit
R1(config)#router eigrp 1
R1(config-router)#network 10.10.1.0 0.0.0.255
R1(config-router)#network 192.168.1.0
R1(config-router)#no auto-summary
R1(config-router)#exit
R1(config)#int tunnel 0
R1(config-if)#no ip split-horizon eigrp 1
R1(config-if)#no ip next-hop-self eigrp 1
R1(config-if)#exit
R1(config)#
Spoke1 Configuration
R2(config)#interface tunnel 0
R2(config-if)#ip address 192.168.1.2 255.255.255.0
R2(config-if)#ip nhrp authentication vpn
R2(config-if)#ip nhrp map 192.168.1.1 1.1.1.1
R2(config-if)#ip nhrp map multicast 1.1.1.1
R2(config-if)#ip nhrp network-id 1
R2(config-if)#ip nhrp nhs 192.168.1.1
R2(config-if)#tunnel source Ethernet0/0
R2(config-if)#tunnel mode gre multipoint
R2(config-if)#ip nhrp shortcut
R2(config-if)#exit
R2(config)#router eigrp 1
R2(config-router)#network 10.10.2.0 0.0.0.255
R2(config-router)#network 192.168.1.0
R2(config-router)#no auto-summary
R2(config-router)#exit
R2(config)#
Hub (R1) Configuration
Step 1: Define IKEv2 Proposal
R1(config)# crypto ikev2 proposal PROPOSAL-R1
R1(config-ikev2-proposal)# encryption aes-cbc-192 aes-cbc-256
R1(config-ikev2-proposal)# group 14 20 24
R1(config-ikev2-proposal)# integrity sha256 sha384
R1(config-ikev2-proposal)# exit
Step 2: Define IKEv2 Policies
R1(config)# crypto ikev2 policy POLICY-R1
R1(config-ikev2-policy)# proposal PROPOSAL-R1
R1(config-ikev2-policy)# exit
Step 3: Define IKEv2 Keyring
R1(config)# crypto ikev2 keyring  KEYRING-R1
R1(config-ikev2-keyring)# peer   dmvpn_node
R1(config-ikev2-keyring)# address 0.0.0.0 0.0.0.0
R1(config-ikev2-keyring)# pre-shared-key cisco@123
R1(config-ikev2-keyring)# exit
Step 4: Define IKEv2 Profile
R1(config)# crypto ikev2 profile IKEv2-PROFILE-R1
R1(config-ikev2-profile)# match identity remote address 0.0.0.0 0.0.0.0
R1(config-ikev2-profile)# match address local 0.0.0.0
R1(config-ikev2-profile)#  authentication local pre-share
R1(config-ikev2-profile)# authentication remote pre-share
R1(config-ikev2-profile)# keyring  local KEYRING-R1
R1(config-ikev2-profile)# exit
Step 5: Define IPSEC Settings
R1(config)#crypto IPsec transform-set TSET-R1 esp-aes 256 esp-sha-hmac
R1(cfg-crypto-trans)# mode tunnel
R1(cfg-crypto-trans)# exit
R1(config)#crypto IPsec profile IPSEC-PROFILE-R1
R1(ipsec-profile)# set transform-set TSET-R1
R1(ipsec-profile)#  set ikev2-profile IKEv2-PROFILE-R1
Step 5: Apply IPSEC Profile to the Tunnel Interface
R1(config)#  interface Tunnel 0
R1(config-if)# tunnel  protection ipsec profile IPSEC-PROFILE-R1
Spoke1(R2)  Configuration
R2(config)# crypto ikev2 proposal PROPOSAL-R2
R2(config-ikev2-proposal)# encryption aes-cbc-192 aes-cbc-256
R2(config-ikev2-proposal)# group 14 20 24
R2(config-ikev2-proposal)# integrity sha256 sha384
R2(config-ikev2-proposal)# exit
R2(config)# crypto ikev2 policy POLICY-R2
R2(config-ikev2-policy)# proposal PROPOSAL-R2
R2(config-ikev2-policy)# exit
R2(config)# crypto ikev2 keyring  KEYRING-R2
R2(config-ikev2-keyring)# peer   dmvpn_node
R2(config-ikev2-keyring)# address 0.0.0.0 0.0.0.0
R2(config-ikev2-keyring)# pre-shared-key cisco@123
R2(config-ikev2-keyring)# exit
R2(config)# crypto ikev2 profile IKEv2-PROFILE-R2
R2(config-ikev2-profile)# match identity remote address 0.0.0.0 0.0.0.0
R2(config-ikev2-profile)# match address local 0.0.0.0
R2(config-ikev2-profile)#  authentication local pre-share
R2(config-ikev2-profile)# authentication remote pre-share
R2(config-ikev2-profile)# keyring  local KEYRING-R2
R2(config-ikev2-profile)# exit
R2(config)#crypto IPsec transform-set TSET-R2 esp-aes 256 esp-sha-hmac
R2(cfg-crypto-trans)# mode tunnel
R2(cfg-crypto-trans)# exit
R2(config)#crypto IPsec profile IPSEC-PROFILE-R2
R2(ipsec-profile)# set transform-set TSET-R2
R2(ipsec-profile)#  set ikev2-profile IKEv2-PROFILE-R2
R2(config)#  interface Tunnel 0
R2(config-if)# tunnel  protection ipsec profile IPSEC-PROFILE-R2
Same way…Configure Spoke2 (R3) router with DMVPN and IPsec IKEv2 Configurations..!
Verification
....................................................................... Thank you very much..! ....................................................................................
