07-16-2020 07:19 AM - edited 10-28-2020 02:44 PM
According to recent studies, such as the Verizon's Data Breach Investigations Report, Credential theft is one of the most common ways a network is breached by external adversaries. The use of username and passwords alone to connect to a network is no longer considered a secure approach. Many companies are employing Multi-Factor Authentication (MFA) solutions with VPN technologies to secure external access to network resources.
Cisco’s Duo is a leading MFA solution and is an essential pillar of Cisco’s Zero-Trust Strategy. Duo easily integrates with Cisco VPN solutions to provide extra layers of security as well as great visibility into network access.
There are a variety of ways Duo can integrate with ASA and Firepower VPN to provide Two Factor authentication. This document will show the different ways to integrate with Duo, the Pros and Cons of each approach and the user experience expected from each setup. This document is mainly focused on theoretical concepts and does not contain configuration or feature specific details. Some additional resources can be found at the end of the document for further education.
The information in this document is based on the following software and hardware versions:
Before discussing the different integration options, an overview of the Duo components involved would help understand the flows that will be described later in this document.
The Duo Authentication Proxy is an on-premises software service that can be installed either on a Windows Server or a Linux machine. It receives authentication requests from a local network device or application via RADIUS or LDAP, optionally performs primary authentication against an existing LDAP directory or RADIUS authentication server, and then contacts Duo to perform secondary authentication. Once the user goes through second factor authentication (received as a push notification from Duo Mobile, or as a phone call, etc.), the Duo proxy returns access approval to the requesting device or application.
The Duo Access Gateway or DAG secures cloud and web applications using the SAML 2.0 Authentication standard. SAML delegates authentication from a Service Provider (SP) to an Identity Provider (IdP) and is used for single sign-on (SSO) solutions.
Protected applications or SPs redirect users to the Duo Access Gateway server in the network. Duo Access Gateway acts as a SAML IdP, authenticating the users using an existing primary authentication source for credential verification, and then prompting for two-factor authentication before permitting access to the SAML application.
Duo Access Gateway supports local Active Directory (AD) and OpenLDAP directories as identity sources, as well as on-premises or cloud SAML IdPs. It can be installed on a Windows Server (2012 or later) as an IIS virtual Site or as a Docker container in most modern Linux distributions.
Note: Duo recently released the “Duo-Hosted SSO” Beta feature. This feature allows the Application to connect to the Cloud directly for Primary and Secondary Authentication without the need to install a DAG in the network. This feature is in BETA phase at the time of writing.
Duo is a SaaS offering and the Duo cloud is where most of the functionality is located. All policy configuration, reporting, endpoint visibility and management is done on the web interface hosted in the cloud. Some basic configuration is done on the Proxy and DAG to connect them to the Primary authentication source and the cloud.
The cloud also holds details about user and endpoint that connect to the network or to protected applications. Details such as username, email address, phone number, type of device and many more can be found in the web console.
It is important to mention that the Duo Cloud does not store or see user passwords and does not perform any primary authentication. Primary authentication is always handled by the external identity store connected to the Proxy or DAG, whether it is an AD, LDAP server or a SAML IdP.
This section shows the different ways Duo can be integrated with Cisco AnyConnect VPN solutions.
The first setup involves a Cisco Firewall, ISE and Duo Authentication Proxy. The same concept applies if a Cisco FTD or ASA was used. With this setup, RADIUS will be chained between the ISE and Authentication proxy to perform Two Factor Authentication. RADIUS requests from the Firewall will reach ISE first which are then sent to the Duo Authentication proxy. The diagram below illustrates the flow of this setup:
Adding the Duo Proxy behind the ISE deployment works well in already existing VPN environments that need an additional layer of security using MFA. There is no need to change any VPN configuration on the Firewalls. ISE will act as a single source of truth for all authentication requests coming from network devices. ISE only needs to be configured to send certain requests to the Duo Proxy while allowing other RADIUS requests to pass through the normal authentication and authorization flows.
With this setup, the user experience will vary depending on how the Duo Authentication proxy is configured.
Using the RADIUS Auto Append mode, the user will see the standard AnyConnect authentication prompt upon connection. In the Password Field, the user will be required to enter their Primary password, followed by a separating character and then their Secondary authentication method of choice appended to their password. The Second Factor can be written as:
If a second factor is not chosen, a push will automatically be sent. If the user does not have the Duo mobile app, a phone call back will be used. The figure below shows an example:
Note: The separating character can be configured in the Authentication Proxy configuration file. By default, it is a “ , ”. The Proxy does not differentiate if this character is already part of the user’s primary password. Take caution when choosing the separator and make sure it is not a character that is allowed in the user’s password.
The same user experience applies for WebVPN access through the browser:
Using the RADIUS Challenge Mode, the user will see the standard AnyConnect authentication prompt upon connection. Once they submit their username and password, without appending anything, they will be presented with a Challenge Prompt to choose the second factor of choice. They can use Push Notification, SMS codes or the OTP code generated on the Duo Mobile App as seen below:
The same applies for WebVPN access through the browser:
If a user authenticates with their primary credentials but their account is not registered with Duo, they will see the following prompt after successful Primary authentication which requests them to enroll:
Going to the specified link will start the enrollment process as shown below:
Note: This is one way to perform enrollment. The link below shows other possible enrollment options for Duo: https://duo.com/docs/enrolling-users
The following table lists the Pros and Cons for this approach:
Pros |
Cons |
Pointing RADIUS requests directly to ISE allows it to filter RADIUS requests going to the Duo Proxy. The filtration can be done based on conditions such as Network Device Groups, VPN Tunnel Group name, Network devices IP, Username and many more. |
Duo Authentication Proxy does not support using MS-CHAP protocol with RADIUS requests when using an AD as the Primary Authentication source. This will prevent the use of Password-Management on the Firewall which allows users to reset AD passwords when they expire through AnyConnect. |
Works well with features such as Profiling and Posture as the RADIUS Change of Authorization (CoA) flow is unaffected. |
Extra considerations need to be taken into account when it comes to High Availability and Failover between ISE and the Proxy. |
RADIUS attributes such as Downloadable Access-list (DACL) and Security Group Tags (SGTs) can be used. |
Chaining RADIUS across multiple devices may add additional latency to the authentication request. |
Easy and fast to setup in an existing VPN environment. |
Un-enrolled users will be prompted to enroll using an HTTPs link as explained below. |
The second setup involves a Cisco Firewall, ISE and Duo Authentication Proxy. The same concept applies if a Cisco FTD or ASA was used.
This setup is similar to the one mentioned before with one difference. The ISE and Duo Proxy positions are swapped. The VPN connection will terminate on the Firewall which will then send a RADIUS request to the Authentication proxy directly. The proxy will send the request to ISE to perform Primary Authentication and authorization.
Adding the Duo Proxy in front of the ISE deployment works well in an environment where password management is needed for VPN users. It is also suitable to organizations that don’t have direct control over their ISE setup and would rather avoid any major changes there.
With this setup, the same user experience mentioned in the previous setup, using the “RADIUS Auto Append Mode”, the “RADIUS Challenge” mode or User Enrollment, still applies.
Note: RADIUS Auto Append Mode is not supported when using MS-CHAP as the authenticating protocol. If MS-CHAP protocol is enabled on the firewall and used for VPN authentication, the user’s actual password is never sent throughout the communication. The Duo Authentication proxy will not see the factor of choice. With this setup, the user simply enters their Primary credentials when authenticating. If they have Duo enabled on their phone, they get a push notification. If not, they will get a phone call back. If the user does not have a Duo Account, an enrollment link will be sent.
Pros |
Cons |
Pointing RADIUS requests directly to the Proxy allows the use of MS-CHAP protocol. As mentioned above, the Duo Proxy supports MS-CHAP only when its primary authentication source is a RADIUS server. Users will be able to change their passwords via AnyConnect if it expires. |
All RADIUS requests generated from the firewalls will go through the proxy. This will add additional load on the proxy as the filtration mechanisms are not as granular as ISE.
RADIUS attributes such as DHCP attributes, Security Group Tags (SGTs), group-policy names…etc can be used. |
Firewall configuration needs to change and point to the Proxy as the RADIUS AAA server for VPN authentication |
No major changes on the ISE side as it is not aware there is a second authentication flow. Only the IP and shared secret of the proxy needs to be added. |
Features such as Profiling and Posture will not work as expected since the Duo Proxy does not support the RADIUS Change of Authorization (CoA) packet generated from ISE and will be dropped. |
Un-enrolled users will be prompted to enroll using an HTTPs link. |
The use of Downloadable Access-lists (dACLs) is not possible with this setup. When ISE pushes a dACL name the ASA attempts to download the contents through another RADIUS request which is not recognized by the Proxy. |
Extra considerations need to be taken into account when it comes to High Availability and Failover |
The third setup involves a Cisco Firewall, ISE and Duo Authentication Proxy. The same concept applies if a Cisco FTD or ASA was used.
This setup is different than the ones mentioned above in that no RADIUS chaining is used. The Cisco Firewalls have the ability to perform Primary and Secondary authentication separately with two different servers.
This setup works well for an existing VPN and ISE deployment. The only change needed is to add an additional authentication method on the Firewall without changing existing VPN configuration. In addition, two factor authentication is possible while achieving total separation of Primary and Secondary Authentication methods to satisfy Compliance requirements or possible security policies.
Note: The Primary Authentication server configured on the Firewall does not have to be a RADIUS server, it can also be an LDAP server.
With this setup, the user will be prompted to enter their username, their password and their factor of choice in three separate fields as seen below:
The options for the second factor are Push, Phone, SMS or OTP from the Duo mobile App.
Pros |
Cons |
Using this approach, no changes on the ISE are needed. The firewall existing configuration will also remain unchanged, only a secondary authentication server needs to be added under the tunnel-group. |
The use of Password management is not possible with this setup. Enabling Password-Management will enable MS-CHAP protocol for both Primary and Secondary Authentication methods. The Duo Proxy will not accept requests using MS-CHAP. |
RADIUS attributes such as DHCP attributes, Security Group Tags (SGTs), group-policy names, DACLs…etc can be used. |
Users not known to the Duo cloud can’t go through Inline enrollment with this setup. Other enrollment options need to be used. For more details, the following link can be used: https://duo.com/docs/enrolling-users |
Features such as Profiling and Posture will work as expected since the RADIUS Change of Authorization (CoA) flow remains the same. |
No RADIUS chaining is used reducing the latency and allows greater flexibility. |
The fourth setup involves a Cisco Firewall, an LDAP server and Duo Authentication Proxy. The same concept applies if a Cisco FTD or ASA was used.
This setup relies completely on the LDAP protocol in order to perform authentication and authorization. It is a simple setup for the environments that don’t have a dedicated AAA server. Primary Authentication is performed against the LDAP server while the Duo cloud handles the second factor authentication. Once both authentications pass, the user is allowed basic access. Optionally, LDAP attribute maps can be used to provide different levels of access based on the received LDAP attributes from the server.
The figure below shows the flow in detail:
With this setup, the user will be able to use the Append mode as explained earlier. The user will see the standard Anyconnect authentication prompt upon connection. In the Password Field, the user will be required to add their Primary password, followed by a separating character and then their Secondary authentication method of choice appended to their password. The Second Factor can be: Push, Phone callback, SMS or a One Time Password (OTP) generated from the Duo mobile App.
Note: The separating character can be configured in the Authentication Proxy configuration file. By default, it is a “,”. The Proxy does not differentiate if this character is already part of the user’s primary password. Take caution when choosing the separator and make sure it is not a character that is allowed in the user’s password.
Pros |
Cons |
No need for a dedicated AAA server for Authentication and Authorization. LDAP attribute maps on the Firewall can be used. |
Limited authorization capabilities with LDAP attribute maps as opposed to a AAA server. |
Password management is possible to allow users to change their passwords when it expires. This requires LDAPs to be enabled between the Firewall and the Duo Proxy. |
Users not known to the Duo cloud can’t go through Inline enrollment with this setup. Other enrollment options need to be used. |
Existing firewall configuration needs to change. LDAP requests need to point to the Duo Proxy instead of directly to the LDAP server. |
The fifth setup does not involve the use of any on-prem Duo applications. In this setup, the Firewall will directly connect to a AAA or LDAP server for Primary authentication and authorization. Once successful, the Firewall will connect to the Duo Cloud using the LDAPs protocol for secondary authentication. There is no need to install the Duo Proxy or Access Gateway.
This setup is similar to the 3rd one mentioned earlier, meaning two separate authentication destinations are used which are the AAA or LDAP servers and the Duo Cloud.
* Note: This setup is officially supported by Duo only on ASA and ASA with Firepower Services. Integration with FTD is technically possible but not officially supported. The FTD integration is limited to version 6.5+ and the FDM (Firepower Device Management) On-Box management service. FTDs that are managed by an FMC (Firepower Management Center) will not be able to use this setup.
The figure below illustrated the flow:VPN connection initiated to the Cisco Firewall. The credentials and second factor of choice is provided by the user.
This setup works well for an existing VPN deployment that needs to enable MFA quickly and efficiently without installing additional on-prem applications. The only change needed is to add an additional authentication method on the Firewall without changing existing VPN configuration. In addition, two factor authentication is possible while achieving total separation of Primary and Secondary Authentication methods to satisfy Compliance requirements or possible security policies.
The options for the second factor are Push, Phone, SMS or OTP from the Duo mobile App as explained earlier. A similar user experience is observed when using the Clientless WebVPN Portal.
Note, with this setup, it is possible to customize the user experience for the Clientless WebVPN Portal. Rather than showing a username, Password and Second Password field, the user will be asked to enter his Primary credentials first:
Once the Primary credentials are entered and confirmed to be correct, the user is presented with a prompt to choose their 2nd method of authentication:
This customization applies only to the WebVPN portal and not to the AnyConnect Authentication Prompt. The link below explains how the Sign-in Page is customized: https://duo.com/docs/ciscoasa-ldap#modify-the-sign-in-page
Pros |
Cons |
Easy to integrate with an existing VPN setup. No need to install any On-Prem Duo services such as the Duo Authentication Proxy or Access Gateway. |
The firewall needs to communicate with the Cloud directly on TCP port 636. Need to make sure that this port is allowed to the internet from the Firewall without going through Proxies. |
If ISE is used as the Primary source of authentication, RADIUS attributes such as DHCP attributes, Security Group Tags (SGTs), group-policy names, DACLs as well as CoA can be used. |
Users not known to the Duo cloud can’t go through Inline enrollment with AnyConnect. Other enrollment options need to be used*. For more details, the following link can be used: https://duo.com/docs/enrolling-users |
Password Management is possible with MS-CHAPv2 with this setup allowing the users to change their passwords through AnyConnect if they expire. |
Duo Certificates need to be imported and managed on the ASA to trust communication with the LDAPs service of the Duo Cloud. |
No chaining is used reducing the latency and allows greater flexibility. |
No failover or redundancy considerations are needed for the secondary authentication. |
* It is possible to manage 2FA devices and perform Inline Enrollment with Duo through the Clientless WebVPN portal if the customization mentioned above is configured.
The final setup uses the Duo Access Gateway and the SAML standard for authentication. In this setup, the Firewall acts as a Service Provider and the Duo Gateway acts as an Identity Provider. It supports inline self-service enrollment and the Duo Prompt for AnyConnect and web-based SSL VPN logins. Primary and Secondary authentication occur at the identity provider, not at the Firewall itself.
Cisco ASA SSO requires ASA version of 9.7.1.24, 9.8.2.28, 9.9.2.1 or higher of these releases, or 9.10 and later, plus AnyConnect 4.6 or later. Prior versions of ASA firmware and AnyConnect do not support SAML login or use a different browser experience.
Note: SAML is not supported on Cisco FTD firewalls at the time of writing.
The figure shown below shows the flow in detail:
Note: The SAML authentication flow can also be achieved using Duo Single Sign-On instead of an On-Prem Duo Access Gateway. Duo Single Sign-on is a cloud hosted Security Assertion Markup Language (SAML) 2.0 identity provider that secures access to VPN as well as cloud applications with users’ existing directory credentials (like Microsoft Active Directory or Google Apps accounts).
This feature is a public beta phase and available for use. The same concepts discussed earlier apply to the Duo Single Sign-on approach. For more details, the following link can be used: https://duo.com/docs/sso#overview
With this setup, the user will be presented with the following authentication prompt window when the VPN session is initiated. This Window is from the AnyConnect embedded browser:
The user also has the option to add or manage their settings and devices:
Finally, if a user has valid domain credentials but is not yet enrolled with Duo, they will see the following prompt after they enter their username and password:
The same user experience applies for WebVPN access through the browser.
Pros |
Cons |
More pleasant user experience using the AnyConnect built-in browser. |
No authorization capabilities using SAML and DAG. Must integrate with a AAA directly for Authorization. (DACLs, SGTs…etc) |
Un-enrolled users will be prompted to enroll using Inline enrollment. |
DAG installation and integration takes some time as opposed to Authentication proxy. |
The user has the ability to add and manage 2FA devices from the Duo portal. |
If integrated with ISE for authorization, RADIUS attributes such as DHCP attributes, Security Group Tags (SGTs), group-policy names, DACLs…etc can be used. |
The use of Password management is not possible with this setup. Users can not change their AD password through the AnyConnect authentication prompt. |
If integrated with ISE for authorization, features such as Profiling and Posture will work as expected since the RADIUS Change of Authorization (CoA) flow remains the same. |
Throughout this document, multiple methods to integrated Duo with the VPN infrastructure have been presented, each with its own advantages and disadvantages, components, flows and protocols. The table below summarizes the details discussed:
Integration Scenario |
Protocols involved |
Components used |
RADIUS Chaining |
Password Management |
CoA Support |
RADIUS attributes |
Inline Enrollment |
ASA Support |
FTD Support |
ISE RADIUS Proxy and Duo Authentication Proxy |
RADIUS |
ISE, Duo Authentication Proxy, Duo Cloud |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Duo Authentication Proxy and ISE Primary Authentication Source |
RADIUS |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Primary and Secondary Authentication servers |
RADIUS/LDAP |
ISE/LDAP server, Duo Authentication Proxy, Duo Cloud |
No |
No |
Yes |
Yes |
No |
Yes |
Yes |
Duo Authentication Proxy and LDAP |
LDAP |
No |
Yes |
No |
Yes |
Yes |
Primary and Secondary Authentication with LDAPs |
RADIUS/LDAP and LDAPs |
Duo Cloud |
No |
Yes |
Yes* |
Yes* |
Limited** |
Yes |
Yes*** |
Duo Access Gateway and SAML Authentication |
SAML |
Duo Access Gateway, Duo Cloud |
No |
No |
Yes* |
Yes* |
Yes |
Yes |
No |
* When integrated with a RADIUS server for authorization
** Only through the Clientless WebVPN portal when Portal Customization is configured. Not possible with AnyConnect Authentication Prompt.
*** FTD Version 6.5 and only with FDM.
Duo for Cisco AnyConnect VPN with ASA or Firepower
Duo Authentication Proxy reference guide
Multi-factor Authentication using Duo (LDAP) for RA VPN through REST API on FDM
Top Work! Would be lovely to see a similar post with the configuration snippets of the ASA and Duo for each topology.
Thank you Aref. I will keep it in mind for the next document. In the mean time, I have a reference section with links for the configurations if you are interested.
Excellent presentation of the options available. Thanks for sharing the work!
Glad you liked it Marvin.
Thank you Warren.
I would like to know the configuration guide (ASA, DAP) scenarios number 3.
Please send the configuration to me.
And I have any question Scenarios number 5 can support with ISE Posture?
Thank you for sharing
I dont have the configuration available at the moment but the resources added at the bottom of the article should help you get started.
For the fifth scenario, I haven't tested posture specifically but theoretically it should work if you are using ISE as your primary authentication and authorization server.
Zaid
Hello, @zalkurdi
Thanks for your reply to my question.
I see update the table Pros and Cons of scenario number 5.
Have you tested it with ISE Posture?
Excellent article Zaid!! Very informative.
