12-13-2012 12:10 AM - edited 08-29-2017 01:43 AM
With the release of AC 3.0 on mobile devices we have the chance of connecting any smartphone to an ikev2 flexvpn headend.
AC 30 has been released for Apple.
https://itunes.apple.com/us/app/cisco-anyconnect/id392790924?mt=8
Release notes are available here:
Anyconnect on smart device will integrate seamlessly into a flexvpn head end without any tweaking on the router.
Per RFC5996, If we use EAP to authenticate a client, the hub MUST be authenticated by providing a certificate.
The underlying reason is the following:
iIf we were using a PSK instead and one person has access to the client and to the head end infrastructure, by using arp poisoining he could impersonate the hub and then decode the user password.
By using a certificate we avoid this situation.
! Definition of Radius config since when EAP is defined, the router proxy simply the request to a radius server
! Working radius are Cisco ACS [ EAP-MD5] Cisco ISE [ EAP-MSCHAP-V2, EAP-MD5, EAP-GTC] Microsoft Radius [ EAP-MSCHAP-V2] Linux Freeradius [ EAP-MD5/EAP-GTC/EAP-MSCHAP-V2]
aaa new-model
aaa group server radius freeradius
server-private 172.16.0.254 auth-port 1812 acct-port 1813 key cisco123
aaa authentication login win7 group freeradius
aaa accounting network default start-stop group freeradius
!Definition of the local certificate truspoint.
!Here I'm using enrollment terminal since I want to select the Webserver template from the Microsoft win2008 CA. SCEP gives access to the ike intermediate template which is not suitable
crypto pki trustpoint anyconnect
enrollment terminal
subject-name cn=R1-HUB.cisco.com,ou=ikev2,ou=TAC,o=Cisco
revocation-check none
rsakeypair flexanyconnect 2048
crypto pki certificate chain anyconnect
certificate 18180951000000000A8D
certificate ca 77E790F86C3BAD9647633D8428015203
! Integrity SHA-1 is required by anyconnect to properly select the right PRF
crypto ikev2 proposal myprop
encryption aes-cbc-256
integrity sha1
group 5
crypto ikev2 policy mypol
match fvrf any
proposal myprop
!Ikev2 profile definition matching the IKE IDentity defined on the client
crypto ikev2 profile default
match identity remote key-id anyconnect_remote_access
match identity remote key-id cisco.com
identity local dn
authentication remote eap query-identity
authentication local rsa-sig
dpd 60 2 on-demand
aaa authentication eap win7
aaa authorization user eap cached
aaa accounting eap default
virtual-template 1
! Authentication local is rsa sig / remote is EAP - We need to query the remote identity.
! PKI trustpoint need to be anchored as security measure. Without that we can't select our certificate
! accounting is important if the radius provide the pool ip address
! authorization user eap cached will load up the attributes received by the radius during the EAP authentication [ eg IP , IKE Routing, ...]
crypto ipsec transform-set default esp-aes 256 esp-sha-hmac
mode tunnel
crypto ipsec profile default
set ikev2-profile default
! Virtual template loopback unnumbered address
interface Loopback0
description VT source interface
ip address 10.0.0.1 255.255.255.255
interface Ethernet0/0
description LAN
ip address 192.168.100.1 255.255.255.0
interface Ethernet0/1
description WAN
ip address 172.16.0.1 255.255.255.0
!Virtual template do not need a tunnel source [ not required]
! ip unnumbered to loopback is required
! Tunnel mode ipsec ipv4 needed for AnyConnect
interface Virtual-Template1 type tunnel
ip unnumbered Loopback0
tunnel mode ipsec ipv4
tunnel protection ipsec profile default
ip local pool mypool 192.168.200.1 192.168.200.254
ip route 0.0.0.0 0.0.0.0 172.16.0.254 name route_to_internet
access-list 99 permit any
In this example radius is provided on a Linux PC running freeradius.
cisco Cleartext-Password := "cisco"
Framed-IP-Address = 172.16.1.1,
Service-Type = Framed-User,
Service-Type = Login,
Cisco-AVPair +="ipsec:route-set-interface=1"
Radius is providing:
Upgrade or install Anyconnect from your vendor store.
The configuration is really simple. It's just a matter of few fields to fill in.
First of all, you have to install the CA server in your trusted profile. The easiest is to access that CA Certificate via http
http://<mywindows2008_ca_server>/certsrv
When we download the CA cert, we are prompted to enter the pin and the CA server is installed in the smart device.
Very easy operation either add the IP or the dns name you will connect.
Remember if it's an IP, then you need a SAN field in your router certificate that will match the dns reverse resolution the client will do when connecting.
If it's a valid DNS name, then it need to match the CN from the router certificate or at least the SAN field from the same certificate
Self signed certs are NOT working.
Turn on "Connect with IPSEC"
Modify Authentication from "EAP-Anyconnect" [ which is ASA specific] to EAP-MD5 / GTC / MSCHAP-V2 depending on the radius infrastructure you've in house] . Here in my example, I will use EAP-MD5.
In our case it's "cisco.com"
During the negotiation, Anyconnect will prompt for user and password.
That user will be checked against the radius server by using the eap framework.
At this stage, the router is forwarding the request back and forward between Anyconnect and the radius.
As soon the ACCESS-ACCEPT has been received by the router [ from the radius].
The router will parse the attributes and provide the required IP / IKE routing / Other parameters either to the client and to the virtual-access interface that has been created on the router.
FlexVPN is a modular VPN that simplify designs and deployment.
This is the next generation solution.
If you have any questions, please feel free to comment.
Olivier Pelerin
CCIE Security #20306
TAC Escalation VPN - Brussels
Great post
can you btw tell me how to get EAP-GTC to work in ACS ?
And do you know if I can integrate ACS with LDAP identity store if I use EAP-GTC as an authentication mechanism ?
again great post and thanks alot
Thanks for your feedback.
My bad. EAP-GTC is not implemented as radius Phase I , just as inner method. I will update the document.
It seems ISE supports more protocols
http://www.cisco.com/en/US/docs/security/ise/1.0/user_guide/ise10_man_id_stores.html [ table-5-1]
Cheers,
Olivier
Np at all .. I was hoping that I missed something
I have also tried to get EAP-GTC working with ISE but without any luck so I am beginning to suspect that EAP-GTC is only supported as an inner method in ISE
regards
Gudmundur
Could be - I never used ISE so far.
thanks for doing this great post
just have small question, how can we enable split tunnel in this scenario.
best regards
bebo
Hello Bebo,
Thanks for your comments.
Flexvpn / Anyconnect supports Split-tunneling
If your policy is on the radius, then you would add the following setting
Cisco-AVPair += "ipsec:route-set=prefix 10.0.0.0/8"
[ Assuming you want to tunnel ONLY traffic to 10/8
If your policy is local, then you would add the following attribute under your local authorization policy
route set access-list <..>
The ACL as well will contains the destination networks you want to reach from the client
Cheers
Olivier
Great post Olivier,
I have a cuestion,,, Do you need any license in the headend? I hay a router ASR1000 and i would implement this solution,,
Thanks in advance,
regards
Cruz
The only platforms where licensing is required (ASR1001 or ASR1002-X) just requires the 'normal' ipsec license.
Cheers,
It's working ! Thanks a lot
I tried this solution, but it does not work under Cisco Secure Client 5.0.00246 and IOS-XE 17.03.05.
After successful EAP-MD5 authentication, anyconnect client strangely additionally requests to authenticate with pre-shared key (for id IKE_IDENTITY), and finally IKE sa authentication failed.
Oct 31 02:50:34.677: IKEv2:sending taolei@tjbn.net [EAP-Id] as username to AAA
Oct 31 02:50:34.678: IKEv2:(SA ID = 1):[IKEv2 -> AAA] Authentication request sent
Oct 31 02:50:34.682: IKEv2:(SA ID = 1):[AAA -> IKEv2] Successful response received
Oct 31 02:50:34.683: IKEv2-ERROR:Address type 2147516374 not supported
Oct 31 02:50:34.683: IKEv2:Received response from authenticator
Oct 31 02:50:34.683: IKEv2:(SESSION ID = 23,SA ID = 1):Sending EAP status message
Oct 31 02:50:34.683: IKEv2:(SESSION ID = 23,SA ID = 1):Building packet for encryption.
Payload contents:
EAP Next payload: NONE, reserved: 0x0, length: 8
Code: success: id: 215, length: 4
Oct 31 02:50:34.683: IKEv2:(SESSION ID = 23,SA ID = 1):Sending Packet [To 111.30.231.214:10319/From 192.168.15.22:4500/VRF i0:f0]
Initiator SPI : C46CDC364AC00D53 - Responder SPI : 651C80AECF8CC1FF Message id: 4
IKEv2 IKE_AUTH Exchange RESPONSE
Oct 31 02:50:34.683: IKEv2-PAK:(SESSION ID = 23,SA ID = 1):Next payload: ENCR, version: 2.0 Exchange type: IKE_AUTH, flags: RESPONDER MSG-RESPONSE Message id: 4, length: 80
Payload contents:
ENCR Next payload: EAP, reserved: 0x0, length: 52
Oct 31 02:50:34.683: IKEv2:(SESSION ID = 23,SA ID = 1):Starting timer (90 sec) to wait for auth message
Oct 31 02:50:34.696: IKEv2:(SESSION ID = 23,SA ID = 1):Received Packet [From 111.30.231.214:10319/To 192.168.15.22:4500/VRF i0:f0]
Initiator SPI : C46CDC364AC00D53 - Responder SPI : 651C80AECF8CC1FF Message id: 5
IKEv2 IKE_AUTH Exchange REQUEST
Oct 31 02:50:34.697: IKEv2-PAK:(SESSION ID = 23,SA ID = 1):Next payload: ENCR, version: 2.0 Exchange type: IKE_AUTH, flags: INITIATOR Message id: 5, length: 128
Payload contents:
AUTH Next payload: NONE, reserved: 0x0, length: 56
Auth method PSK, reserved: 0x0, reserved 0x0
Oct 31 02:50:34.697: IKEv2:(SESSION ID = 23,SA ID = 1):Stopping timer to wait for auth message
Oct 31 02:50:34.697: IKEv2:(SESSION ID = 23,SA ID = 1):Send AUTH, to verify peer after EAP exchange
Oct 31 02:50:34.697: IKEv2:(SESSION ID = 23,SA ID = 1):Verify peer's authentication data
Oct 31 02:50:34.697: IKEv2:(SESSION ID = 23,SA ID = 1):Use preshared key for id TJBN, key len 32
Oct 31 02:50:34.697: IKEv2:(SESSION ID = 23,SA ID = 1):[IKEv2 -> Crypto Engine] Generate IKEv2 authentication data
Oct 31 02:50:34.697: IKEv2:(SESSION ID = 23,SA ID = 1):[Crypto Engine -> IKEv2] IKEv2 authentication data generation PASSED
Oct 31 02:50:34.698: IKEv2-ERROR:(SESSION ID = 23,SA ID = 1):: Failed to authenticate the IKE SA
Oct 31 02:50:34.698: IKEv2:(SESSION ID = 23,SA ID = 1):Verification of peer's authentication data FAILED
Oct 31 02:50:34.698: IKEv2:(SESSION ID = 23,SA ID = 1):Sending authentication failure notify
Oct 31 02:50:34.698: IKEv2:(SESSION ID = 23,SA ID = 1):Building packet for encryption.
Payload contents:
NOTIFY(AUTHENTICATION_FAILED) Next payload: NONE, reserved: 0x0, length: 8
Security protocol id: Unknown - 0, spi size: 0, type: AUTHENTICATION_FAILED
Oct 31 02:50:34.698: IKEv2:(SESSION ID = 23,SA ID = 1):Sending Packet [To 111.30.231.214:10319/From 192.168.15.22:4500/VRF i0:f0]
Oct 31 02:50:34.698: IKEv2-PAK:(SESSION ID = 23,SA ID = 1):Next payload: ENCR, version: 2.0 Exchange type: IKE_AUTH, flags: RESPONDER MSG-RESPONSE Message id: 5, length: 80
Payload contents:
ENCR Next payload: NOTIFY, reserved: 0x0, length: 52
Oct 31 02:50:34.698: IKEv2:(SESSION ID = 23,SA ID = 1):Auth exchange failed
Oct 31 02:50:34.699: IKEv2-ERROR:(SESSION ID = 23,SA ID = 1):: Auth exchange failed
Oct 31 02:50:34.699: IKEv2:(SESSION ID = 23,SA ID = 1):Abort exchange
Oct 31 02:50:34.699: IKEv2:(SESSION ID = 23,SA ID = 1):Deleting SA
Oct 31 02:50:34.699: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Close PKI Session
That's very clear steps for Flex VPN configuration
