minkumar
Forward Syslog Messages to external Server using ACS
Introduction
This Document describes the steps on How to Forward the syslog messages to External Server Using ACS 5.x
Prerequisites
Connectivity of ACS 5.x with Syslog server.
Requirements
ACS 5.x
Any syslog server
Components Used
ACS 5.4
KiwiSyslog server
Configure
Go to System Administration>Configuration>Log configuration>Remote Log Targets>Create
step1: Give a name to the syslog server
step2: You can define type(syslog)
step3: Type the IP address of syslog server
Step4: define port (514)
Step5: Define Fcility code as LOCAL
Step6: define max length as 1024
Specify which messages should be forwarded to the new created Syslog Server.
In this example, I have selected Radius  Accounting as I want to forward Accounting logs. However you can select  anyother category as well.
Step1: Go to System Administration>Configuration>Log Configuration>Logging Categories>Global
Step2: Select Radius accounting
Then move the available External Syslog Server to the Selected Targets and click submit.
Step1: Go to System  Administration>>Configuration>Log Configuration>Logging  Categories>Global>Edit"Radius Accounting"
Submit the changes.
Verify
Generate some traffic and you should now be able to see the messages on the server.
bpa-emhazen
Community Member
Thanks, that was very easy to follow.
vishnurnth1
Followed the same and we are able to receive the syslog messages in the external server,
But we have noticed the below issues
integrated the ACS logging message to External Syslog Servers, and identified that the logs displayed there is have // instead of one /,
eg:  Domain/username ( In ACS )
 Domain//username ( When forwarded to external Syslog Server )
We have tried this in Multiple Syslog servers and the result is same,
We are suspecting that ACS is adding an additional Slash at the time of sending the logs, Is there an option to check the sent logs in ACS ? "
Thank you,
Vishnu
vthaluru
Hi Vishnu,
You can  enable log to local log target from logging categories ,then we can able to see same logs in the localstore.logs.
you can run the reports for same category and we can able to see the data.
VenkataKrishna
Please rate helpful posts and mark correct answers.
vishnurnth1
Thanks VenkataKrishna,
As you suggested i have tried that and in that the username is displaying with only on / Backslash,
but whenever we are forwarding this to an external server the output of username is displaying with //slash,
Eg : Domain/username ( In ACS )
 Domain//username ( In External Server )
Is there anything which we can do in ACS to correct the same ?
Thank you,
Vishnu
vthaluru
Hi Vishnu,
What is the version of ACS ?
VenkataKrishna
vishnurnth1
ACS version : 5.8
Vishnu
