I am receiving the error "No module.template file found in module." when attempting to install the .tgz file, even though the module.template file is clearly in the archive. Is there a new version or are there additional changes I should make to the archive?
I found the solution... The files are in a directory (ECCCyberSFModule) once untarred and uncompressed. They should be in the root of the gzipped tar file. I re-created the tgz file (e.g. tar czf ECCCyberSFModule.tgz module.template ECCCyberSFModule.pl ) and the resultant file was accepted as a valid module.
