davebush
The attached document guides you through configuring a Site-To-Site VPN between a FirePower device and a Meraki device.
Martin L
Thanks for sharing!
david.paganini
Thanks!! Great document!!
davebush
Heads up that more recent version of both Meraki code and FirePower code has eliminated IKE1. You can still follow this document (which I need to update) but modify things to use IKE2 instead. Make sure your settings on IKE2 match up on both sides, and your site to site VPN from a FP to a Meraki device should work fine.
Cole Riese
Hi @davebush , are there any instructions for setting up a site-to-site VPN between FTD and Meraki using FMC?
asif.akram
@davebush , Do you have a document to configure a S2S VPN between FTD & Meraki using FMC? That FMC already have Full mesh configured using a couple of FTDs and now want to add a MX in that topology. Will you be able to assist? Thanks.
davebush
Unfortunately, I do not have any instructions to do that.
