Vladimir Larionov
Community Member
after reimage MARS i have problem with configuration restore
please help
[pnadmin]$ pnrestore -m1 -pXXX.XXX.XXX.XXX:/nfs -sXXX.XXX.XXX.XXX:/nfs
cannot obtain signal handler
ACE_Service_Config::open: Success
Thread 1024:PN-0100:Opened Oracle connection
Thread 1024:PN-0012:Created 'DbClient' instance
Thread 1024:PN-0101:Closed Oracle connection
Thread 1024:PN-0013:Deleted 'DbClient' instance
Thread 1024:Param Name is SCHEMA_VERSION, the value is 4360.
Thread 1024:Param Name is PRODUCT_VERSION, the value is 436.
Thread 1024:Param Name is OS_VERSION, the value is 0.
Thread 1024:Mounting  remote NFS path successfully!
It is going to take a while if data volume is large ...
Thread 1024:PN-0013:Deleted 'PnLogger' instance
[pnadmin]$ nd between date  and
Satheshkumar Nallasamy
Community Member
Thank you for your posting and interest in the Cisco Support Community.  For best practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions
For technical questions related to a Cisco Product or Technology, we encourage you to post on the Network Professionals Forum (NetPro). For your question on <specify Cisco Product or technology> you can go to <put the link to the specific forum, e.g. if the question is related to MARS troubleshoot, put the post in General under Security
