Peter Long
Level 6
Level 6
What have I done wrong? See code below
regex BLOCKED_DOMAIN_1 "\facebook.\com"
access-list TRAFFIC_TO_INSPECT_FOR_BLOCKED_DOMAINS extended permit tcp any any eq http
class-map type regex match-any CLASS_MAP_BLOCKED_DOMAIN_LIST
match regex BLOCKED_DOMAIN_1
class-map type inspect http match-all CLASS_MAP_DEFINE_TRAFFIC_TO_INSPECT
match request header host regex class CLASS_MAP_BLOCKED_DOMAIN_LIST
class-map CLASS_MAP_HTTP_TRAFFIC
match access-list TRAFFIC_TO_INSPECT_FOR_BLOCKED_DOMAINS
policy-map type inspect http POLICY_MAP_HTTP_INSPECTION
parameters
  protocol-violation action drop-connection
match request method connect
  drop-connection log
class CLASS_MAP_DEFINE_TRAFFIC_TO_INSPECT
  reset log
policy-map POLICY_MAP_INSIDE_INTERFACE
class CLASS_MAP_HTTP_TRAFFIC
service-policy POLICY_MAP_INSIDE_INTERFACE interface inside
Aniket Rodrigues
Community Member
Can you check with this:
regex BLOCKED_DOMAIN_1 "www.facebook.com"
parameters
drop-connection log
service-policy POLICY_MAP_INSIDE_INTERFACE interface outside
AR
Peter Long
Level 6
Level 6
Thanks Aniket - I will try that - I did get it working on the global policy - see my website here http://www.petenetlive.com/TecBin/KB/0000054.htm but Even TAC could not get my original code to work
I will try that out on the test rig and get back to you
Peter Long
Level 6
Level 6
Hi Aniket
Sorry for the Delay - That worked like a charm
just in case anyone searches this and wants both working examples
On the Global Policy
regex domainlist1 "facebook.com"
class-map type regex match-any DomainBlockList
  match regex domainlist1
class-map type inspect http match-all BlockDomainsClass
  match request header host regex class DomainBlockList
policy-map type inspect http http_inspection_policy
class BlockDomainsClass
  reset log
policy-map global_policy
  class inspection_default
service-policy global_policy global
With its own policy
  parameters
  drop-connection log
policy-map POLICY_MAP_OUTSIDE_INTERFACE
service-policy POLICY_MAP_OUTSIDE_INTERFACE interface outside
