dohurd
The PacketFence Remediation Module uses PacketFence's SOAP API in order to forward the IPS event received by SourceFire to PacketFence so that an active response (ie. quarantine a device node) can be performed.
pmapeso
Is this compatible with FMC? I tried to install the module it didn't work. Unzipped or zipped.
